Author Topic: Emulating PWM on non-PWM port on a PIC  (Read 3757 times)
Offline galannthegreatTopic starter
« on: April 30, 2009, 09:15:47 PM »
I am having a little trouble with getting PWM working on my PIC. I am using a non-hardware PWM (CCP) and from what I've been told, it can be emulated via software. My first question would be, how would I go about this?
P.S. even a simple example in pseudo code would be of great help here.
With thanks, Kurt.
Kurt
Offline LunchBox!
Re: Emulating PWM on non-PWM port on a PIC
« Reply #1 on: April 30, 2009, 10:22:19 PM »
are you using the pwm for servo control?
enable a pin as output
loop
set pin high
delay for 1.5ms
set pin low
delay 20ms
goto loop
you can use a timer and interrupts to make your program more efficient too.
Offline hazzer123
« Reply #2 on: May 01, 2009, 01:39:00 AM »
You can use either a straight forward routine with delays, or a more complex interrupt based algorithm.
Here is the easy one.
int duty_cycle = 60; //Duty cycle varies between 0 and 100.
while (1) {
  SetPinHigh();
  delay(duty_cycle);
  SetPinLow();
  delay(100-duty_cycle);
The delay function here would determine your PWM frequency.
It's not a nice way of doing it... but it achieves what you want :)
www.icrobotics.co.uk
« Reply #3 on: May 01, 2009, 10:56:27 AM »
Thank you very much, this will be of help, but I'm curious, how would the interupt based code go?
Kurt
Offline hazzer123
« Reply #4 on: May 01, 2009, 11:25:13 AM »
boolean PWM_state; //global
int duty_cycle;
ISR () { //Interrupt service routine
  if(PWM_state) {
    setPinLow();
    PWM_state = false;
    setTimer(100-duty_cycle); //Set timer to interrupt in this many units of time
  } else {
    setPinHigh();
    PWM_state = true;
    setTimer(duty_cycle); //Set timer to interrupt in this many units of time
int main() {
  configure_MCU(); //Configure pin modes and timer interrupts (and possible other things)
  PWM_state = false;
  duty_cycle = 60;
  do_other_things();
This enables you to do other things while the PWM works. You could also use scheduling to have multiple PWM (you can see this in the arduino SoftwareServo library).
« Last Edit: May 01, 2009, 11:30:17 AM by hazzer123 »
« Reply #5 on: May 01, 2009, 11:51:43 AM »
Thank you this is really helpful, and this will be an even more useful method for my purposes.
Kurt
