Author Topic: PIR Motion Detector Problem  (Read 2330 times)
Offline TeslaTopic starter
« on: May 27, 2009, 07:35:17 PM »
Hi all,
I have a PIR that has an output that floats at .9 volts and sometimes triggers.  How do I get that down to 0 volts?
Thanks you,
Jason
Re: PIR Motion Detector Problem
« Reply #1 on: May 28, 2009, 12:35:24 AM »
use a pull down resistor?
use a 10k resistor from the signal line to gnd and see if that helps...
« Reply #2 on: May 28, 2009, 11:27:29 AM »
Thank you!  I think the problem is with the schmitt trigger IC.  I ordered a new one.  If that doesn't fix the problem, then I'll try the pull down resistor.
« Reply #3 on: May 28, 2009, 03:41:50 PM »
awesome, good luck with that...
and say hi to dellagd next time you see him...
