Beginners: please read this post and this post before posting to the forum.
no, that schematic looks ok...all gnds should be connected so that's good.you do realize that this will waste a heap of power, yes?
Is my schematic correct? Will it output the 0-4 volt signal I am expecting?
well, i may suggest using a separate 12v pack to the motor driver because the motor may introduce some "noise" to the circuit and this can screw up some of your sensor readings.is the 12v running a fan?
Hi,Quote from: StAnkys on May 29, 2009, 05:05:30 AMIs my schematic correct? Will it output the 0-4 volt signal I am expecting?No, you need to swap R1 and R2 since the potentiometer does NOT go from infinite to 50 kOhm, but from ~0 Ohm to 50 kOhmBut it is a very strange and inefficient circuit, what are you using the 0V-4V to (and what current do you need)?There's better ways, especially if you need the variable voltage to be stable.Apart from all that, you need to add several capacitors of different value, or you have just produced a very weird oscillator.Tell us your exact needs and "haves" and a better solution will appear.
