Author Topic: How do I setup an interrupt for this?  (Read 2710 times)
Offline galannthegreatTopic starter
« on: June 07, 2009, 06:49:50 PM »
My friend and I are trying to figure out how to get an interrupt working with this code:
for(x=0;x<200;x++)
output_high(PIN_D1);
delay_us(500);
output_low(PIN_D1);
delay_us(2500);          //left most position
for(x=0;x<200;x++)
delay_us(2500);
output_low(PIN_D1);
delay_us(500);          //right most position
The question I have is how can I get an interrupt to work in this code? and how can I connect the sensor/switch to work as the interrupt?
Is there a better method to accomplish this?
« Last Edit: June 07, 2009, 06:54:36 PM by galannthegreat »
Kurt
Offline sonictj
  • Helpful? 11
    • Tim's Workshop
Re: How do I setup an interrupt for this?
« Reply #1 on: June 08, 2009, 02:12:03 AM »
Can you elaborate on what type of interrupt you want and what the code exactly is doing?
« Reply #2 on: June 08, 2009, 10:31:08 AM »
Sorry for not clarifying this initially.
Okay, so my code is essentially making a servo scan back and forth to its most outer limits, and I want to set up an interrupt for an IR Rangefinder or a PING type sensor. I want the interrupt to be able to stop the servo movement and hold position until nothing is seen by the sensor.
Kurt
Offline sonictj
  • Helpful? 11
    • Tim's Workshop
« Reply #3 on: June 08, 2009, 11:16:45 AM »
I did the same thing on my robot using a stepper motor, but an interrupt isn't the answer.  Interrupts should only be used for very quick tasks.  You want the program to sit and wait for a value.  The way to do this is to declare a bool global variable.  Make a servo function that moves one degree at a time if nothing is in view.
psuedo code
void servo()
if (sensor sees object) return;
else if (sensor sees nothing)
//change servo direction if servo encounters either extreme
 if ((servo_position == max_position) || servo_position == min_position) servo_dir =~ servo_dir;
  move servo 1 degree in the servo_dir direction
