Author Topic: serial programmer question.... atmegas  (Read 3009 times)
Offline jamortTopic starter
« on: June 21, 2009, 12:26:12 AM »
ok so I like to work on 5 projects or so at the same time.... and I really think its a waste of money buying a bunch of serial programmers to add onto each board... so my question is were i normally use atmega 8  or 16 can I build a board with a socket to put the ic chip in and program it then put it in the actual board that im using... I see tools online about removing the chips but nothing about actually doing something to this extint and hope you'll can understand what I'm saying
Offline Joker94
  • Helpful? 26
Re: serial programmer question.... atmegas
« Reply #1 on: June 21, 2009, 03:43:03 AM »
i don't see why not
but some projects it may be easier to have the MCU permanent
if you are building a robot for a competition that requires a demonstration and/or has strict guidelines that requires a serial port on the actual bot make sure that you don't cut corners.
some one in a comp i entered did what your tallking about and when they found he did not follow the guidelines they disqualified him
« Reply #2 on: June 21, 2009, 04:53:16 AM »
Just make one programmer and an ICSP socket on each board.
Something like http://www.evilmadscientist.com/article.php/avrtargetboards
    • RazorConcepts
« Reply #3 on: June 21, 2009, 08:46:22 AM »
I got tired of wiring ICSP headers on protoboard, I had wires going everywhere that just made everything messy. So I made this chip piggyback thing:
This way I can completely skip the ICSP header, and even make circuits and program them all on bread boards. When I want to program I just put it right on top of the chip and connect the ICSP programmer.
« Reply #4 on: June 21, 2009, 07:00:40 PM »
i like the design RAZOR... I was hoping to have something just to stick it in and program it.. normally i only have to program each chip three times so unless its not upright i dont think it will hurt to have it loosely fit as long as it makes connections....
« Reply #5 on: June 22, 2009, 12:33:57 AM »
why not just rig up a small board with a regulator, 28 pin socket and the programmer headers?
« Reply #6 on: June 22, 2009, 01:03:34 AM »
thats basically what i said in my post :P
just hard to understand lol
Offline chelmi
    • Current projects
« Reply #7 on: June 22, 2009, 11:10:57 AM »
My advice: use a ZIF (Zero Insertion Force) socket like this one: http://futurlec.com/Sockets/ZIFU28.shtml
It's a bit more expensive but you won't regret it.
« Reply #8 on: June 22, 2009, 12:39:30 PM »
that looks like the best bet....
