Author Topic: ask OCR3BH, OCR3BL...  (Read 2649 times)
Offline hendrachubbyTopic starter
    • My-Blog
« on: June 21, 2009, 03:07:53 AM »
I want to use PWM on Atmega640, but i found that the timer use 16 bit PWM, and i ussually use 10 bit PWM on Atmega16, The difference i got is the OCR got H and L on it..like OCR3BH and OCR3BL, so can anybody expalin how to control this 2 register like the one on Atmega16 ( only OCR3B ) ?
Here is my code ( but it didt work )
#include <mega640.h>
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include <delay.h>
#define MAX 0xFFFF
void set_ports()
    PORTE = 0b00000000;
    DDRE  = 0b11111111;
    //       |||||||\___0:
    //       ||||||\____1:
    //       |||||\_____2: Status_1
    //       ||||\______3: Status_2
    //       |||\_______4: PWM_1
    //       ||\________5: PWM_2
    //       |\_________6: Status_3
    //       \__________7: Status_4
Timer/Counter 3 initialization
Clock source: System Clock
Clock value: 16000.000 kHz
Mode: Ph. correct PWM top=03FFh
Noise Canceler: Off
Input Capture on Falling Edge
OC3A output: Discon.
OC3B output: Non-Inv.
OC3C output: Non-Inv.
Timer 3 Overflow Interrupt: Off
Input Capture Interrupt: Off
Compare A Match Interrupt: Off
Compare B Match Interrupt: Off
Compare C Match Interrupt: Off
void set_timers()
    TCCR3A  = 0x14;
    TCCR3B  = 0x01;
    TCNT3H  = 0x00;
    TCNT3L  = 0x00;
    ICR3H   = 0x00;
    ICR3L   = 0x00;
    OCR3AH  = 0x00;
    OCR3AL  = 0x00;
    OCR3BH  = 0x00;
    OCR3BL  = 0x00;
    OCR3CH  = 0x00;
    OCR3CL  = 0x00;
/*LED status 3 x*/
void system_led()
    int i;
    for(i = 0; i <= 2; i++)
        PORTB.6 = 1;
        delay_ms(1000);
        PORTB.6 = 0;
        delay_ms(1000);
Motor Control
Motor Kanan :
PWM_1      = PORTE.4 OCR3B
Status_1    = PORTE.2
Status_2    = PORTE.3
Truth Table :
Status_1 = 1, Status_2 = 0 > Motor Kanan Mundur
Status_1 = 0, Status_2 = 1 > Motor Kanan Maju
Motor Kiri  :
PWM_2       = PORTE.5 OCR3C
Status_3    = PORTE.6
Status_4    = PORTE.7
Truth Table :
Status_3 = 1, Status_4 = 0 > Motor Kiri Mundur
Status_3 = 0, Status_4 = 1 > Motor Kiri Maju
void motor_control(float duty_cycle_kanan, int status_1, int status_2, float duty_cycle_kiri, int status_3, int status_4)
    OCR3BH  = MAX*duty_cycle_kanan;
    OCR3BL  = MAX*duty_cycle_kanan;
    PORTE.2 = status_1;
    PORTE.3 = status_2;
    OCR3CH  = MAX*duty_cycle_kiri;
    OCR3CL  = MAX*duty_cycle_kiri;
    PORTE.6 = status_3;
    PORTE.7 = status_4;
/*Motor Brake*/
void brake(int status_1, int status_2, int status_3, int status_4)
    PORTE.2 = status_1;
    PORTE.3 = status_2;
    PORTE.6 = status_3;
    PORTE.7 = status_4;
void main()
    set_ports();
    set_timers();
    system_led();
    while(1)
        motor_control(1,1,0,1,1,0);
        delay_ms(2000);
        motor_control(0.5,1,0,0.5,1,0);
        delay_ms(2000);
        brake(0,0,0,0);
        delay_ms(1000);
        motor_control(1,0,1,1,0,1);
        delay_ms(2000);
        motor_control(0.5,0,1,0.5,0,1);
        delay_ms(2000);
        brake(0,0,0,0);
        delay_ms(1000);
I use this to control 2 DC motor using L298 motor driver, the motor manages to changing direction but the PWM pin can't give the output..anyone can help me with this type of PWM ?
Offline sonictj
  • Helpful? 11
    • Tim's Workshop
Re: ask OCR3BH, OCR3BL...
« Reply #1 on: June 25, 2009, 10:50:09 AM »
To load a value into the two registers you can use shifting
  example
//duty is a 16 bit number
//shifts duty right by 8.  This sets OCR2BH equal to the upper 8 bits of duty
OCR2BH = duty>>8;
// OCR2BL is set to the lower 8 bits of duty
OCR2BL = duty;
// note you may need to use OCR2BL = 0x00FF & duty; to get rid of the top bits, but I think this is unnecessary
