Author Topic: need some help for servo control  (Read 2663 times)
Offline tamamontuTopic starter
« on: June 22, 2009, 07:18:28 AM »
Hi.
I am trying to control a servo using ATMEGA168. I have set the timer1 in pwm mode and set the frequency to 50hz and trying to vary the duty cycle from 0 to 2ms. The servo is a 180deg rotation type.
The servo dosent rotate completely.. Can some one pls help.
thanks
Offline apc3161
Re: need some help for servo control
« Reply #1 on: June 22, 2009, 03:08:44 PM »
When you say it doesn't rotate "completely" do you mean 180 deg. or 360 deg?
« Reply #2 on: June 22, 2009, 07:04:24 PM »
it dosent rotate complete 180 deg.
I went through servo control tutorial in the tutorial section. As per that my understanding is that if i vary the duty cycle from 0ms  2ms.. we can control its complete rotation. I tried to do the same in my code where in i update OCRA1 value from 0ms  to 2 ms.
