Author Topic: Sonar or Optical  (Read 2358 times)
Offline pete2009Topic starter
Sonar or Optical
« on: June 24, 2009, 04:02:09 PM »
Simple question. Which is a more reliable detector. Which one has a higher and less error prone cycle rate?
I want to use in three situations.
1) Wall or object detection (medium distance), rotating on top of robot.
2) Drop off dector (short distance) o see if I'm falling off a mountain or my staircase.
3) Far object predictability (long distance) to make measurements of objects far away, used in conjunction with the medium range to plan a better path.
Any help appreciated.
Offline jamort
Re: Sonar or Optical
« Reply #1 on: June 25, 2009, 05:45:34 AM »
need to know more details about what your trying to do long and short isnt cutting it cause long could be a foot or it could be 10 feet... or it couble be a float point variable....
just about anything you get beside the laser range detectors which cost in the thousands of dollars are going to have there disadvantages....
Offline Joker94
  • Helpful? 26
« Reply #2 on: June 25, 2009, 06:07:19 AM »
it's a bt of give and takeit is hard to pin point one as i don't know
give jamrot and me some details and we'll give you some more detail
« Reply #4 on: June 25, 2009, 08:51:25 AM »
Perfect .. thanks airman.
It shed a lot of light on the situation :)
