Author Topic: Axon with DC motors?  (Read 4981 times)
Offline StephanieTopic starter
« on: June 26, 2009, 06:44:41 PM »
Hello! :-)
I want to make my first robot, and I want to make it autonomous and use Lynxmotion DC motors. So I saw the Sabertooth dual 5A motor controller, which I plan to purchase along with an Axon microcontroller.
But I'm afraid because I have no idea about how to connect the Axon and the Sabertooth together! Do I need to purchase cables or all the needed cables come with them?
Thank you!
Stephanie
--- Stephanie
Re: Axon with DC motors?
« Reply #1 on: June 26, 2009, 06:58:53 PM »
well, you don't need to have any "special" cables to connect these together...
just some hook up wire that can take the amperage.
to hook it up refer to: http://www.dimensionengineering.com/datasheets/Sabertooth2X5QuickStart.pdf
you want the second dip switch setup on page 2. this allows for pwm control, the same as with servos! ;D
look at the attached image. the two control pins get connected to digital pins capable of pwm on the axon.
and remember to keep grounds common.
« Reply #2 on: June 26, 2009, 07:36:36 PM »
Thanks for the help, James! I greatly appreciate it!
Won't I need this kind of cable to connect it to the Axon?
http://www.robotshop.ca/lynxmotion-sc-01-servo-cable.html
Because the hook up wire doesn't have any end to attach to the microcontroller...
Sorry for asking all these questions... :-x
Stephanie
--- Stephanie
« Reply #3 on: June 26, 2009, 08:17:35 PM »
Yeap that'll work. I always make my own though since I own crimpers.
« Reply #4 on: June 26, 2009, 08:50:39 PM »
Thanks, admin!
So, guys:
I made a simple table with everything I'm purchasing from RobotShop. (first row is quantity)
Is that enough to build my first robot? I have nothing but a soldering iron, a wire stripper and protection goggles. Aside from the chassis, am I missing anything (e.g. some peculiar cable, some other required tool)?
I'm a total beginner, so even if you find some very obvious error, please point it out.
Love,
Stephanie
--- Stephanie
« Reply #5 on: June 26, 2009, 08:55:57 PM »
nope, that looks all good!
but if you are planning on powering the axon with those 12V batteries maybe use a heatsink.
it looks like your going to have fun :)
« Reply #6 on: June 26, 2009, 09:22:24 PM »
Thank you again, James!
I think I'll power the Axon with a 6V battery instead. So how do I connect my 12V battery directly to the Sabertooth? Am I already purchasing the cables?  :P
The 12V battery looks like this:
Steph~
PS: Wow, you guys are really helpful. Thanks a lot! I'll make sure to come back to SoR as often as I can!  ;)
« Last Edit: June 26, 2009, 09:27:07 PM by Stephanie »
--- Stephanie
« Reply #7 on: June 26, 2009, 09:26:59 PM »
yeap, 6V-7V2 will do fine, to connect power to the sabertooth you will have to have stripped ends that can go into the terminals. i think you will have to get a female connector (one with prongs sticking out the end) as most battery packs come with crimped ends, if not you are good to go.
« Reply #8 on: June 26, 2009, 09:44:08 PM »
Thanks! Are these suitable female cables?
http://www.robotshop.ca/sfe-170mm-ff-premium-jumper-wires.html
I don't know if I got it right... Will this work?
« Last Edit: June 26, 2009, 09:54:48 PM by Stephanie »
--- Stephanie
« Reply #9 on: June 26, 2009, 09:55:16 PM »
my bad, im always getting confused because of the crimps :P
you want male to male or male to open, preferably male to open.
something like http://www.robotshop.ca/sfe-170mm-mm-premium-jumper-wires.html
« Reply #10 on: June 26, 2009, 10:00:31 PM »
Ah, great! So it's basically Sabertooth to http://www.robotshop.ca/sfe-100mm-wire-jst-blk-blue.html to http://www.robotshop.ca/sfe-170mm-mm-premium-jumper-wires.html to battery?
Too bad I can't mark you as helpful multiple times. Haha :-)
--- Stephanie
« Reply #11 on: June 26, 2009, 10:09:08 PM »
the the male cable, chop it in half, strip the ends and have the stripped ends in the terminals and the male end connected to the battery.
« Reply #12 on: June 26, 2009, 10:15:01 PM »
Got it.
Thanks a lot, James! I hope I'll come back to SoR with a nice robot documented. :-)
--- Stephanie
« Reply #13 on: June 26, 2009, 10:17:54 PM »
so do i mate, your welcome.
