Author Topic: Mecanum  (Read 5628 times)
Offline HadeBeTopic starter
Mecanum
« on: July 07, 2009, 03:24:38 AM »
I want to build an autonomous robot with mecanum wheels. Andymark is a company where you can buy these wheels, so thats not the problem..
My discomforts are about the control system. I can control the turns with a compass.
But my question is about the encoders. I know that lateral movement is not possible when only using encoders for position control. but if the robot moves just forward, is slippage then a problem?
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
    • Ro-Bot-X Designs
Re: Mecanum
« Reply #1 on: July 07, 2009, 05:25:16 AM »
I would suggest the use of an optical mouse sensor instead of encoders. This way you get movement in all directions regardless of wheel slippage. Search the forum for mouse optical sensor hack. It has been done and documented.
Re: Mecanum
« Reply #2 on: August 25, 2009, 08:37:45 AM »
Optical mouse sensors are horrible, actually. Lift your optical computer mouse above the table about 1mm, and watch what happens. You'll see error gets really large if its not always perfectly flush with the table.
Offline Joker94
  • Helpful? 26
Re: Mecanum
« Reply #3 on: August 25, 2009, 05:56:22 PM »
Optical mouse sensors are not good like admin said. I just mounted the one i had lying around on my robot and it didnot work well at all.
Offline Ro-Bot-X
  • Helpful? 25
    • Ro-Bot-X Designs
Re: Mecanum
« Reply #4 on: August 25, 2009, 07:26:02 PM »
Of course it doesn't work. The lens is made so the beam is focused on the mouse pad (really close distance). So at a greater distance, you need to modify (change) the lens. Please look up the optical mouse sensor on this forum, there is someone who did it and it worked.
Offline Joker94
  • Helpful? 26
Re: Mecanum
« Reply #5 on: August 25, 2009, 07:30:33 PM »
i had it mounted skimming the floor. not hovering in mid air but i get what your saying
Offline wil.hamilton
  • Helpful? 6
  • rtfm
Re: Mecanum
« Reply #6 on: August 27, 2009, 05:18:45 PM »
you could always use gyros and accelerometers to get relative motion.
you can get ones that are accurate within a few degrees for not too much.
Offline FingerTech Robotics
Re: Mecanum
« Reply #7 on: August 28, 2009, 01:23:04 PM »
I would like to offer a link to FingerTech's Mecanum Wheels.  They are much cheaper than others and might be a more manageable size (2.125" diameter).
http://www.fingertechrobotics.com/products.php?cat=Wheels+%26+Hubs
[youtube]http://www.youtube.com/watch?v=DhNm0FOIiG0[/youtube]
Hope that helps!
Offline blackbeard
Re: Mecanum
« Reply #8 on: August 28, 2009, 03:46:57 PM »
i'd so buy those wheels if you mounted a flame thrower on that robot while it passed through the buildings :P
Next step: Give them vaginas
