Author Topic: AVR Studios strikes again!!  (Read 3242 times)
Offline Silver_79Topic starter
« on: July 15, 2009, 07:04:00 PM »
      I finish the tutorial that adds the Axon.c (mine is diff name) , control.c and hardware.c along with the makefile and try to rebuild all it gives a error and Vista 32 bit closes it. I did change the make file to my file name thought so I have no Idea why it does this. Can I just use my copy of Visual Studios 2003 I have for this ?
I shall be telling this with a sigh
Somewhere ages and ages hence:
Two roads diverged in a wood, and I–
I took the one less traveled by,
And that has made all the difference.
-Robert Lee Frost-
Re: AVR Studios strikes again!!
« Reply #1 on: July 16, 2009, 04:32:20 PM »
Try it without changing names to anything and see if it still works.
« Reply #2 on: July 19, 2009, 06:31:43 PM »
Once I change the target = back to Axon from what   I changed it to I get the error :
make  *** No rule to make target "Axon.elf" , needed by 'elf '. Stop,
Build failed with 1 errors and zero warnings...
If I change the name back to the name of my file (without ext. of course) It makes windows Vista close with a popup window: AVRStudio MFC Application has stopped working.
-Robert Lee Frost-
« Reply #3 on: July 19, 2009, 08:14:27 PM »
Hmmmm this error happens when you didn't set the folders/filenames/makefile settings properly.
Just start over entirely from scratch using my tutorial.
