Author Topic: AVR Studios, its about time  (Read 3251 times)
Offline Silver_79Topic starter
« on: July 30, 2009, 10:15:35 AM »
Hi all, OK I finally got through the ARV tutorial for the Axon and it built without crashing Vista. There was however one error when it completed that I have listed below:
Warning-timer640.c:355: warning: 'BAD_vect' appears to be a misspelled signal
Will this be a problem when I upload to the robot ? Will it run as intended ? Or is my robot going to try to kill my cat ? :P
I shall be telling this with a sigh
Somewhere ages and ages hence:
Two roads diverged in a wood, and I–
I took the one less traveled by,
And that has made all the difference.
-Robert Lee Frost-
Offline sonictj
  • Helpful? 11
    • Tim's Workshop
Re: AVR Studios, its about time
« Reply #1 on: July 30, 2009, 10:48:02 AM »
I'd be willing to bet it should be BADISR_vect .
Offline wil.hamilton
  • Helpful? 6
  • rtfm
« Reply #2 on: July 30, 2009, 10:56:06 AM »
just google the warning and see if the results are similar for things like what you're trying to do
« Reply #3 on: August 03, 2009, 02:34:27 PM »
I honestly don't know what that warning is, but it hasn't caused me any problems yet! :P
It'll only give you that warning when you do a rebuild-all.
Offline sonictj
  • Helpful? 11
    • Tim's Workshop
« Reply #4 on: August 05, 2009, 12:45:25 AM »
quote from avrlibc
Catch-all interrupt vector
If an unexpected interrupt occurs (interrupt is enabled and no handler is installed, which usually indicates a bug), then the default action is to reset the device by jumping to the reset vector. You can override this by supplying a function named BADISR_vect which should be defined with ISR() as such. (The name BADISR_vect is actually an alias for __vector_default. The latter must be used inside assembly code in case <avr/interrupt.h> is not included.)
#include <avr/interrupt.h>
ISR(BADISR_vect)
    // user code here
I checked the code it should be BADISR_vect, BAD_vect is not an interrupt vector.
The moral of the story is you won't have any problems unless you enable an interrupt without the proper ISR vector.  The BADISR_vect will catch a bat interrupt call.  Unless you write interrupt code you won't notice any problems.  Thats why everything still works ;D.
« Reply #5 on: August 05, 2009, 07:47:55 AM »
good investigative work! I just tried it, and the prob went away.
I'll fix the BADISR_vect issue tonight and upload the corrected code as v1.09.
For now, just open up timer640.c, go to the very bottom of the page, and change BAD_vect to BADISR_vect.
