Author Topic: Axon Problem  (Read 2930 times)
Offline meiralfasiTopic starter
Axon Problem
« on: July 31, 2009, 08:13:15 AM »
Need Help .
I bought Axon Microcontroller  , install software and use bootload,  i uploaded the Servo center program and when i connect the servo to terminal h2 the servo going from side to side then i connect the servo to any terminal same thing happend.
i use a diffrent servo , the same thing happend .
i downloaded the led switch program and nothing happend maybee i got a bad axon microcontroller I'm lost
any help will be appreciated.
PS . infact any program from the source sample code that i download douse not work when i use bootload the is confermation that the program install successfully.
Offline Tomas
Re: Axon Problem
« Reply #1 on: August 03, 2009, 04:22:10 AM »
I had some problems with the premade sourcecode from this site. I also thought the axon unit I got was broken. But it worked programming it. Just try creating something for yourself in AVR studio. It should be pretty easy.
Re: Axon Problem
« Reply #2 on: August 03, 2009, 06:52:16 AM »
I will greatly appreciate if you post a program that actually works.
This is reticules, why the have example in the website that are not working properly.
    • RazorConcepts
Re: Axon Problem
« Reply #3 on: August 03, 2009, 09:11:24 AM »
Could you post exactly what you typed in the command line to get the program to bootload.
Re: Axon Problem
« Reply #4 on: August 03, 2009, 09:41:05 AM »
This is the command line for the bootloader fboot17.exe -b115200 -c2 -paxon_ser.hex -vaxon_ser.hex I got conformation I connected the servo to any pin include H2 the servo go to one side and still pulsing  it dose that with any pin . I uploaded diffrent program and nothing happend.
Re: Axon Problem
« Reply #5 on: August 03, 2009, 02:32:21 PM »
