Author Topic: helpp  (Read 5333 times)
Offline MohdAsyrofTopic starter
helpp
« on: August 01, 2009, 12:00:25 AM »
don't know how to build a path finding robot using a arios sensor  :( :( :( :(
Offline Joker94
  • Helpful? 26
Re: helpp
« Reply #1 on: August 01, 2009, 12:29:45 AM »
what is a arios sensor, please explaine
it may be that i am the only one who dose not know
Offline gaurav.p
  • Go robotics
Re: helpp
« Reply #2 on: August 01, 2009, 12:57:34 AM »
joker94 i m with u ..............i too dun't know what is arios sensor.
please explain it to me too please
-gaurav
Big Things Come In Small Packages!!!
Offline Joker94
  • Helpful? 26
Re: helpp
« Reply #3 on: August 01, 2009, 04:01:13 AM »
i google it and came up with nothing, all i found was somthing to do with sabath
Re: helpp
« Reply #4 on: August 01, 2009, 04:16:45 AM »
same here... some transformers dude...
TS, do you have a link to what you are referring?
paulstreats
  • Guest
Re: helpp
« Reply #5 on: August 02, 2009, 07:15:38 PM »
http://www.ario.com.tw/
this is a company called ariose / ario. they dont appear to have any kind of sensors that could be used for path finding tho...
Offline wil.hamilton
  • Helpful? 6
  • rtfm
Re: helpp
« Reply #6 on: August 02, 2009, 09:03:59 PM »
the only appear to make speakers and microphones, neither of which appear to be useful for a pathfinding robot.  either MohdAsyrof has no idea what he's attempting to do, or we've found the wrong ariose.....
@MohdAsyrof:
what kind of sensor(s) are you using?  if you could provide us with information about them we might be able to help you.
Offline Joker94
  • Helpful? 26
Re: helpp
« Reply #7 on: August 03, 2009, 05:51:51 AM »
i see, i thought it was the name of a particular sensor not a company ;D
Offline gaurav.p
  • Go robotics
Re: helpp
« Reply #8 on: August 03, 2009, 06:48:15 AM »
me too  ;D
Re: helpp
« Reply #9 on: August 09, 2009, 11:24:11 PM »
its really looks like my 'v' key is not functioning very well... "don't know how to build a path finding robot using a various sensor".. sory 4 the trouble..  :-[ :-[ :-[ :-[
Re: helpp
« Reply #10 on: August 10, 2009, 12:37:19 AM »
ahh, ok lol... that makes more sense...
is various a type of sensor or do you mean any sensor?
Offline sonictj
  • Helpful? 11
    • Tim's Workshop
Re: helpp
« Reply #11 on: August 10, 2009, 01:26:01 AM »
I think MohdAsyrof  meant any kind of sesnor.  my preference is to use a scanning Sharp IR, an IR mounted on a servo or stepper, for obstacle detection.  The IR rangefinders have a thin beam which is good for scanning.  I like to use sonar for getting more accurate ranging data.
« Last Edit: August 10, 2009, 12:44:20 PM by sonictj »
  • Helpful? 6
  • rtfm
Re: helpp
« Reply #12 on: August 10, 2009, 12:15:26 PM »
lol, yea, that v helps us a lot.  i have used IR sensors for pathfinding before. sharp ir sensors are very easy to use.  i'd say go with them.  if you don't need the high accuracy that is, readings can vary on what surface it is.  different surfaces give different readings.  sharp ir is generally cheaper than sonar, but sonar is more accurate
Offline offy
Re: helpp
« Reply #13 on: August 17, 2009, 06:42:10 AM »
Wouldn't IR Sensors and sonar be for object avoidance, not line following. Also if I am wrong please correct me, but if an ir sensor is to be used for line following (I don't think it is possible) wont you have problems with the thresh hold since ir sensors can't see within usually 2 inches.
Offline Finnik
Re: helpp
« Reply #14 on: August 17, 2009, 07:21:04 AM »
Offy, the question asked in this topic is about path-finding, not line-following. For path-finding you could use a Sharp IR or sonar as these are ranging sensors and you need to avoid (or find) objects to determine the path to follow.
Indeed, you would not be able to use either Sharp IR or sonar for line-following. Although you could use IR reflectance sensors for example.
Think outside the box... inside is to crowded.
Offline offy
Re: helpp
« Reply #15 on: August 18, 2009, 05:16:36 AM »
My bad. I wasn't thinking when I posted that. Should of read it better
