Don't ad-block us - support your favorite websites. We have safe, unobstrusive, robotics related ads that you actually want to see - see here for more.
After replacing the P channel the motor would turn under one direction. As soon as I toggled directions I heard a pop and nothing worked.
Could the transients be popping the mosfets?
What voltages and currents we dealing with?
Does the PCB check out fine unpopulated?
How does your Xilinx 9572 CPLD turn on the drivers? If you do the wrong pattern, you can create instantaneous shorts.
Stuff overheats before popping?
Yeap, sounds like back emf to me too.Also, got caps across your motor/battery?
