Author Topic: Plastic Thickness  (Read 5390 times)
Offline Joker94Topic starter
  • Helpful? 26
Plastic Thickness
« on: August 05, 2009, 03:06:43 AM »
What thickness plastic do people recomend and or think will be suitable. Whether it is acrylic or HDPE
What do people recomend
Re: Plastic Thickness
« Reply #1 on: August 05, 2009, 03:10:18 AM »
what is it for? a base?
Offline sonictj
  • Helpful? 11
    • Tim's Workshop
« Reply #2 on: August 05, 2009, 03:34:23 AM »
your gonna hate me, but it all depends on the specific use.  This is like the infamous question "whats the microcontroller".  It all depends on your design.  I use .25" acrylic often, because I do a lot of tapping.   I have been known to use 1/8 inch for stuff too.  Unfortunately the best answer to your question is it depends.  If you can be more specific as Smash suggested we may be able better answer your question more to your liking.
« Reply #3 on: August 05, 2009, 03:49:16 AM »
for a base i would recommend 1/4"...
but this all does depend on the size of the part and which part it is.
  • Helpful? 26
« Reply #4 on: August 05, 2009, 04:30:40 AM »
Well to start off with it will be just the base but eventually it will become a fullon bot.
I attached a picture of my chassi idea. And i an leaning towards 1/4 inch as i can tap it. and maybe 1/8 for y arm and other add ons. All of this will be hopfully joined by custom aluminum brackets.
Offline wil.hamilton
  • Helpful? 6
  • rtfm
« Reply #5 on: August 05, 2009, 06:48:18 AM »
if you're going to be using it for a base, i would go with the 1/4 especially if you're using hdpe, acrylic is stiffer and you could probably get away with using 1/8 and still have it stiff enough, but, it also depends on the dimensions.
  • Helpful? 26
« Reply #6 on: August 06, 2009, 02:18:53 AM »
i am leaning towards 1/4. As i can tap the plastic.
i still have not decided whether to use acrylic or HDPE  :-\
« Reply #7 on: August 06, 2009, 06:10:48 AM »
if you do decide to use hdpe, and find a reasonable distributor, tell me...
i have been searching for someone besides mc master carr for ages.
  • Helpful? 26
« Reply #8 on: August 06, 2009, 06:15:15 AM »
i have GB plastics, they are my local plastics place
http://www.gbplastics.com.au/
« Last Edit: August 06, 2009, 06:16:46 AM by Joker94 »
Offline matt liao
« Reply #9 on: August 07, 2009, 12:20:05 AM »
It all depends, the thickness of plastic parts usually is 1~5mm
