Author Topic: search the easier solution to control a motor  (Read 3463 times)
Offline jorjTopic starter
« on: August 12, 2009, 07:19:19 PM »
I need a motor that rotate in 60 degree right and when the motor terminate the 60 degree right the motor rotate 60 degree left and continue this loop until I turn off the motor
I don't want to do an electrical circuit and to compute
I search after the easier solution
Offline billhowl
  • Helpful? 32
Re: search the easier solution to control a motor
« Reply #1 on: August 12, 2009, 07:37:37 PM »
May be you can try car windscreen wipers motor
http://en.wikipedia.org/wiki/Windscreen_wiper
Offline wil.hamilton
  • Helpful? 6
  • rtfm
« Reply #2 on: August 12, 2009, 07:46:57 PM »
uh, or you just use a servo?  that's what they're built to do
« Reply #3 on: August 12, 2009, 07:58:57 PM »
Thanks billhowl & wil.hamilton
Wil.hamilton I think that I don't understand you
maybe You can explain me
« Reply #4 on: August 13, 2009, 12:27:58 AM »
a servo:
with the right code will do that, here is some arduino code to "sweep" the servo from left to right.
void loop()
  for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
this will sweep the servo from 0 degrees to 180 degrees then back again...
this could easily be made to do 60 degree sweeps.
« Reply #5 on: August 13, 2009, 12:53:26 AM »
a servo:
Allways read the original post, then you don't generate annoying space waste for others to scroll through ;)
  • Helpful? 6
  • rtfm
« Reply #6 on: August 13, 2009, 09:12:13 AM »
@soren
i more think he didn't want to the calculation of of a control circuit for using a dc motor
what smash gave him is one of the easiest things he could do
another option is using the GM10 (http://www.pololu.com/catalog/product/195) which has a mechanical stop at 60 deg both directions
so you would just have to turn the motor on one way and then the other
Offline blackbeard
« Reply #7 on: August 13, 2009, 10:33:56 AM »
jori i mean this in the best way but you're a bit hard to understand. if English is your second language maybe an online translator might be a bit easier. as for limiting the range of motion i'd like to know more about what it's used for. if it's small enough you could just add physical blocks to alter the range of motion.
Next step: Give them vaginas
« Reply #8 on: August 13, 2009, 03:14:39 PM »
Oh, come on guys. billhowl read the post and nailed the solution IMO.
What the OP asks for is a continous back-and-forth motion of 60°.
A DC motor with a linkage akin to a wiper motor, scaled to whatever size needed IS the simplest solution - wax on/wax off nothing more to it :)
  • Helpful? 6
  • rtfm
« Reply #9 on: August 13, 2009, 08:21:14 PM »
building something like a wiper assembly would probably be too complex to build in the size he would need it.
anyway, here is how wipers work: http://auto.howstuffworks.com/wiper1.htm
Offline billhowl
  • Helpful? 32
« Reply #10 on: August 13, 2009, 10:13:14 PM »
This is the wiper motor that I talk about, all in one assembly.
You just need to buy the motor and use it.
Here are some project page.
http://www.scary-terry.com/wipmtr/wipmtr.htm
