Author Topic: Netbook robot  (Read 4448 times)
Offline offyTopic starter
Netbook robot
« on: August 14, 2009, 01:40:56 PM »
So I am getting back into robotics (mostly programming again) and am wondering if this is possible. Could I just use a netbook as my mcu. Can it be used to power motors and etc?
Netbook I might buy: http://www.newegg.com/Product/Product.aspx?Item=N82E16834152093
Offline GearMotion
  • Helpful? 24
    • CircuitGizmos
Re: Netbook robot
« Reply #1 on: August 14, 2009, 01:44:04 PM »
You will need some way for the Wind to communicate with the real world. USB?
Re: Netbook robot
« Reply #2 on: August 14, 2009, 01:49:06 PM »
How many volts does a USB port give off? 3? I could do that since it has power and ground. But I would not know how to stop, start, and change direction of the servo.
    • RazorConcepts
Re: Netbook robot
« Reply #3 on: August 14, 2009, 01:59:24 PM »
5 volts at 500ma
The best way would be to have the netbook communicate to a microcontroller that controls the servos. This way the netbook acts as the main brains, the decision-maker while the microcontroller does the dirty work.
Re: Netbook robot
« Reply #4 on: August 14, 2009, 02:10:29 PM »
so I could use the roboduino or any other mcu and connect it through the USB port and have the serial communication running. I can't believe I didn't think of that.
Offline GearMotion
  • Helpful? 24
    • CircuitGizmos
Re: Netbook robot
« Reply #5 on: August 14, 2009, 02:14:05 PM »
As mentioned 5V. Officially limited to 100 mA until the USB device is initialized and requests more. Not that you can't draw more from the port, but expect a laptop to be power-miserly.
This: U401 at http://www.usbmicro.com is a simple USB device for I/O, LCD, stepper motor, SPI, 1-wire, for example.
Offline GearMotion
  • Helpful? 24
    • CircuitGizmos
Re: Netbook robot
« Reply #6 on: August 14, 2009, 02:15:33 PM »
You would need to use a USB/serial converter for gereral microcontrollers. Sparkfun sells some.
The Arduino (not all types) have one on-board.
Offline blackbeard
Re: Netbook robot
« Reply #7 on: August 15, 2009, 07:12:48 AM »
the arduino duemilanove already connects through usb so i'd think you wouldn't need any converter. besides i've found that my basic stamp 2 hates them with a passion. what is it you want to do with the netbook? if it's just programming it might be easier to to just use a microcontroler (arduino is $30 vs 300 for a mini laptop). if you want something like a a rolling skype machine then like others have said you're going to need to hook it up to a microcontroller
Next step: Give them vaginas
Re: Netbook robot
« Reply #8 on: August 16, 2009, 12:35:57 PM »
You could just use a USB to parallel or eg. the experimenters board that Velleman sells.
You will need an extra power source if you want it to do anything serious.
Offline Asellith
  • Helpful? 9
    • CorSec Engineering
Re: Netbook robot
« Reply #9 on: August 17, 2009, 03:16:01 PM »
check out Phidgets USB interfaces. This will let you use external power and avoid programming a microcontroller and all that involves.
http://www.trossenrobotics.com/store/c/3104-Phidget-I-O-Boards.aspx
Jonathan Bowen
CorSec Engineering
www.corseceng.com
