Author Topic: AVR programming  (Read 2900 times)
Offline spykid99Topic starter
AVR programming
« on: August 18, 2009, 05:31:21 AM »
Hi, i have some questions about the AVR microcontroller range
1. AVR code looks like mumbojumbo ( i can code basic/vb reasonably) so;
2. Is their an alternative to the standard AVR programming language??? (e.g. C)
Any help appreciated
Spykid99
"Do not worry about your difficulties in Mathematics. I can assure you mine are still greater." ~Albert Einstein
    • RazorConcepts
Re: AVR programming
« Reply #1 on: August 18, 2009, 06:34:17 AM »
The AVR code is in C  ???
The Arduino environment is still C but much easier to understand (using actual words instead of crazy symbols), but with Arduino you have a limited choice of microcontrollers.
Re: AVR programming
« Reply #2 on: August 18, 2009, 03:16:30 PM »
Yeah, i think it was the crazy symbols that got me; ill probably go with arduino
Offline benji
Re: AVR programming
« Reply #3 on: August 18, 2009, 03:32:47 PM »
you can use CodeVision AVR to code all AVR microcontrollers in C .
its a Great compiler with rich C Libraries which make programming easier.
specially it has a wizard to initialize peripherals (you dont have to worry about values ,just answer the wizard questions and it will write appropriate code)
good ol' BeNNy
Re: AVR programming
« Reply #4 on: August 18, 2009, 03:52:29 PM »
OK, ill check that out
