Squirrels have fuzzy tails.
The ESC is plugged into port H3 on the Axon
QuoteThe ESC is plugged into port H3 on the AxonHow many wires, and which wires, to where? Measure them each with a multimeter.If you are applying a voltage to H3, you are possibly frying the Axon. With the Axon H3 not told to do anything, but with everything turned on, H3 should have 0V.
There are three wires from the esc to the Axon H3 port.
Quote from: emoseman on August 26, 2009, 09:29:19 PMThere are three wires from the esc to the Axon H3 port.And the voltages on each are? My theory is that the middle one is supplying power to the Axon (bad!). You should only have two wires: ground and signal.
