Buy an Axon, Axon II, or Axon Mote and build a great robot, while helping to support SoR.
The specification of [...]
The problem is, the transistor is not responding to the emitter at the moment.Not at all. Could you advise me what have I done wrong?
As you see, the operating voltage of the emitter is 1.5VDC, 60mA. So I supplied 1.5V using a variable DC adaptor(1.5~13V, 600mA).
I don't know how much current your motor takes,
Some componentes shown in that schematics are not available now.So, I will get them at once and test it right away.
This circuit should help.
Is it ok if I put 10 emitters in this circuit?
The transistor I mentioned earlier will move above the emitter and I will arrange the number of the emitter so that the transistor(motor) could stay turned on as long as it passes over the emitters.I think I must test first, but I assume the number of the emitters needs to be 10pcs(or a little more).
