Author Topic: FBOOT17 problem  (Read 2901 times)
Offline ukeshTopic starter
FBOOT17 problem
« on: September 02, 2009, 11:59:47 PM »
hey guys!
I'm using fboot17 for uploading the hex file to axon. But i got a new laptop and it only has vista in it and i get an error saying that 'the system cannot open com3 port as requested by the application'. i tried all the available com ports and i get the same error and im sure that only  axon is connected to the port i'm using. so what do i do?
EDIT: OK, i installed windows xp sp2 version using the virtual pc application. I i tried uploading the hex file and for some reason i keep getting the "wrong device informations " error. In vista the axon is connected in com port 2 and in xp also i've connected the axon on com port 2 and i've tried changing the baud rates, yet i keep getting the same error.! can some one guide me??..its kind of urgent :(
« Last Edit: September 04, 2009, 09:01:10 AM by ukesh »
Re: FBOOT17 problem
« Reply #1 on: September 05, 2009, 06:23:04 AM »
Are you 100% sure you did the command right, with file names/locations correctly?
When you plug in the Axon, which com port appears in system devices?
Re: FBOOT17 problem
« Reply #2 on: September 05, 2009, 06:55:47 AM »
Yes, I'm sure about the command. The axon appears on com port 2 in windows vista.
Re: FBOOT17 problem
« Reply #3 on: September 05, 2009, 07:15:15 AM »
Vista 32bit or 64bit?
Re: FBOOT17 problem
« Reply #4 on: September 05, 2009, 10:12:38 AM »
nevamind admin, installed windows xp and everything works fine :) thanks!
