Buy an Axon, Axon II, or Axon Mote and build a great robot, while helping to support SoR.
#include <mega2560.h>#include <delay.h>#include <stdio.h>#include <stdlib.h>#include <lcd.h>#define MAX 0xFFint i;int encoder_axis_1, encoder_axis_2, encoder_axis_3, encoder_axis_4, encoder_axis_5;unsigned char lcd_encoder_axis_1[5], lcd_encoder_axis_2[5], lcd_encoder_axis_3[5], lcd_encoder_axis_4[5], lcd_encoder_axis_5[5];void lcd_setting(){ /* LCD on port C */ #asm .equ __lcd_port=0x08 ;PORTC #endasm}void oscillator_setting(){ /* Crystal Division Factor : 1 */ #pragma optsize- CLKPR=0x80; CLKPR=0x00; #ifdef _OPTIMIZE_SIZE_ #pragma optsize+ #endif} void ports_setting(){ /* board configuration F0F7K0K7 E0 A0 E7 A7 H0 J7 H7 uC J0 B4 C7 B7 C0 G0 G5 L0L7D0D7 */ PORTF =0b00000000; DDRF =0b11111111; //DDRK = 0xFF; //PORTK = 0x00; //PORT A //DDRA = 0b11111111; //PORT B //DDRB = 0b11111111; //PORT C //DDRC = 0b11111111; PORTD= 0b00000000; DDRD = 0b00000000; //PORTE = 0b00000000; DDRE = 0b11111111; //PORT G //DDRG = 0b11111111; //PORTH //DDRH = 0b11111110; //PORTJ //DDRJ = 0b11111110; //PORTL= 0b11111111; DDRL = 0b11111111; void timers_setting(){ /* Timer/Counter 5 initialization Clock source: System Clock Clock value: 16000.000 kHz Mode: Ph. correct PWM top=00FFh OC5A output: Discon. OC5B output: Non-Inv. OC5C output: Non-Inv. Noise Canceler: On Input Capture on Falling Edge Timer 5 Overflow Interrupt: Off Input Capture Interrupt: Off Compare A Match Interrupt: Off Compare B Match Interrupt: Off Compare C Match Interrupt: Off */ TCCR5A=0x29; TCCR5B=0x81; TCNT5H=0x00; TCNT5L=0x00; ICR5H=0x00; ICR5L=0x00; OCR5AH=0x00; OCR5AL=0x00; OCR5BH=0x00; OCR5BL=0x00; OCR5CH=0x00; OCR5CL=0x00;} void interrupt_setting(){ /* External Interrupt(s) initialization INT0: On INT0 Mode: Rising Edge INT1: On INT1 Mode: Rising Edge INT2: On INT2 Mode: Rising Edge INT3: On INT3 Mode: Rising Edge INT4: On INT4 Mode: Rising Edge INT5: On INT5 Mode: Rising Edge INT6: On INT6 Mode: Rising Edge INT7: On INT7 Mode: Rising Edge */ EICRA=0xFF; EICRB=0xFF; EIMSK=0xFF; EIFR=0xFF;} void motor_control(float duty_cycle_axis_1, int input_1_axis_1, int input_2_axis_1, float duty_cycle_axis_2, int input_1_axis_2, int input_2_axis_2){ /* Motor Control Axis_1 : PWM_axis_1 = PORTL.5 OCR5C input_1_axis_1 = PORTL.6 input_2_axis_1 = PORTL.7 Axis_2 : PWM_axis_2 = PORTL.4 OCR5B input_1_axis_2 = PORTL.2 input_2_axis_2 = PORTL.3 */ OCR5BH = MAX*duty_cycle_axis_2; OCR5BL = MAX*duty_cycle_axis_2; OCR5CH = MAX*duty_cycle_axis_1; OCR5CL = MAX*duty_cycle_axis_1; PORTL.2 = input_1_axis_2; PORTL.3 = input_2_axis_2; PORTL.6 = input_1_axis_1; PORTL.7 = input_2_axis_1;}void motor_stop(){ motor_control(0,0,0,0,0,0);}interrupt [INT1] void ext_int1_isr(void){ encoder_axis_1++;}interrupt [INT2] void ext_int2_isr(void){ encoder_axis_2++;}interrupt [INT3] void ext_int3_isr(void){ encoder_axis_3++;}interrupt [INT4] void ext_int4_isr(void){ encoder_axis_4++;}interrupt [INT5] void ext_int5_isr(void){ encoder_axis_5++;}void test_encoder(){ #asm ("sei"); while( encoder_axis_1 <= 145 ) { motor_control(0.5,1,0,0,1,0); } motor_stop(); #asm ("cli");}void brake_axis_2_off(){ PORTF.0 = 1;}void brake_axis_3_off(){ PORTF.1 = 1;}void brake_axis_2_on(){ PORTF.0 = 0;}void brake_axis_3_on(){ PORTF.1 = 0;}void main(void){ lcd_init(16); oscillator_setting(); ports_setting(); timers_setting(); lcd_setting(); interrupt_setting(); lcd_gotoxy(0,0); lcd_putsf("ready"); delay_ms(3000); lcd_clear(); while(1) { brake_axis_2_off(); brake_axis_3_off(); } }
PORTE.2 = input_1_axis_2; PORTE.3 = input_2_axis_2; PORTE.6 = input_1_axis_1; PORTE.7 = input_2_axis_1;
// CodeVisionAVR C Compiler// (C) 1998-2005 Pavel Haiduc, HP InfoTech S.R.L.// I/O registers definitions for the ATmega2560#ifndef _MEGA2560_INCLUDED_#define _MEGA2560_INCLUDED_#pragma used+sfrb PINA=0;sfrb DDRA=1;sfrb PORTA=2;sfrb PINB=3;sfrb DDRB=4;sfrb PORTB=5;sfrb PINC=6;sfrb DDRC=7;sfrb PORTC=8;sfrb PIND=9;sfrb DDRD=0xa;sfrb PORTD=0xb;sfrb PINE=0xc;sfrb DDRE=0xd;sfrb PORTE=0xe;sfrb PINF=0xf;sfrb DDRF=0x10;sfrb PORTF=0x11;sfrb PING=0x12;sfrb DDRG=0x13;sfrb PORTG=0x14;sfrb TIFR0=0x15;sfrb TIFR1=0x16;sfrb TIFR2=0x17;sfrb TIFR3=0x18;sfrb TIFR4=0x19;sfrb TIFR5=0x1a;sfrb PCIFR=0x1b;sfrb EIFR=0x1c;sfrb EIMSK=0x1d;sfrb GPIOR0=0x1e;sfrb EECR=0x1f;sfrb EEDR=0x20;sfrb EEARL=0x21;sfrb EEARH=0x22;sfrw EEAR=0X21; // 16 bit accesssfrb GTCCR=0x23;sfrb TCCR0A=0x24;sfrb TCCR0B=0x25;sfrb TCNT0=0x26;sfrb OCR0A=0x27;sfrb OCR0B=0x28;sfrb GPIOR1=0x2a;sfrb GPIOR2=0x2b;sfrb SPCR=0x2c;sfrb SPSR=0x2d;sfrb SPDR=0x2e;sfrb ACSR=0x30;sfrb OCDR=0x31;sfrb SMCR=0x33;sfrb MCUSR=0x34;sfrb MCUCR=0x35;sfrb SPMCSR=0x37;sfrb RAMPZ=0x3b;sfrb EIND=0x3c;sfrb SPL=0x3d;sfrb SPH=0x3e;sfrb SREG=0x3f;#pragma used-#define WDTCSR (*(unsigned char *) 0x60)#define CLKPR (*(unsigned char *) 0x61)#define PRR0 (*(unsigned char *) 0x64)#define PRR1 (*(unsigned char *) 0x65)#define OSCCAL (*(unsigned char *) 0x66)#define PCICR (*(unsigned char *) 0x68)#define EICRA (*(unsigned char *) 0x69)#define EICRB (*(unsigned char *) 0x6a)#define PCMSK0 (*(unsigned char *) 0x6b)#define PCMSK1 (*(unsigned char *) 0x6c)#define PCMSK2 (*(unsigned char *) 0x6d)#define TIMSK0 (*(unsigned char *) 0x6e)#define TIMSK1 (*(unsigned char *) 0x6f)#define TIMSK2 (*(unsigned char *) 0x70)#define TIMSK3 (*(unsigned char *) 0x71)#define TIMSK4 (*(unsigned char *) 0x72)#define TIMSK5 (*(unsigned char *) 0x73)#define XMCRA (*(unsigned char *) 0x74)#define XMCRB (*(unsigned char *) 0x75)#define ADCL (*(unsigned char *) 0x78)#define ADCH (*(unsigned char *) 0x79)#define ADCW (*(unsigned int *) 0x78) // 16 bit access#define ADCSRA (*(unsigned char *) 0x7a)#define ADCSRB (*(unsigned char *) 0x7b)#define ADMUX (*(unsigned char *) 0x7c)#define DIDR2 (*(unsigned char *) 0x7d)#define DIDR0 (*(unsigned char *) 0x7e)#define DIDR1 (*(unsigned char *) 0x7f)#define TCCR1A (*(unsigned char *) 0x80)#define TCCR1B (*(unsigned char *) 0x81)#define TCCR1C (*(unsigned char *) 0x82)#define TCNT1L (*(unsigned char *) 0x84)#define TCNT1H (*(unsigned char *) 0x85)#define ICR1L (*(unsigned char *) 0x86)#define ICR1H (*(unsigned char *) 0x87)#define OCR1AL (*(unsigned char *) 0x88)#define OCR1AH (*(unsigned char *) 0x89)#define OCR1BL (*(unsigned char *) 0x8a)#define OCR1BH (*(unsigned char *) 0x8b)#define OCR1CL (*(unsigned char *) 0x8c)#define OCR1CH (*(unsigned char *) 0x8d)#define TCCR3A (*(unsigned char *) 0x90)#define TCCR3B (*(unsigned char *) 0x91)#define TCCR3C (*(unsigned char *) 0x92)#define TCNT3L (*(unsigned char *) 0x94)#define TCNT3H (*(unsigned char *) 0x95)#define ICR3L (*(unsigned char *) 0x96)#define ICR3H (*(unsigned char *) 0x97)#define OCR3AL (*(unsigned char *) 0x98)#define OCR3AH (*(unsigned char *) 0x99)#define OCR3BL (*(unsigned char *) 0x9a)#define OCR3BH (*(unsigned char *) 0x9b)#define OCR3CL (*(unsigned char *) 0x9c)#define OCR3CH (*(unsigned char *) 0x9d)#define TCCR4A (*(unsigned char *) 0xa0)#define TCCR4B (*(unsigned char *) 0xa1)#define TCCR4C (*(unsigned char *) 0xa2)#define TCNT4L (*(unsigned char *) 0xa4)#define TCNT4H (*(unsigned char *) 0xa5)#define ICR4L (*(unsigned char *) 0xa6)#define ICR4H (*(unsigned char *) 0xa7)#define OCR4AL (*(unsigned char *) 0xa8)#define OCR4AH (*(unsigned char *) 0xa9)#define OCR4BL (*(unsigned char *) 0xaa)#define OCR4BH (*(unsigned char *) 0xab)#define OCR4CL (*(unsigned char *) 0xac)#define OCR4CH (*(unsigned char *) 0xad)#define TCCR2A (*(unsigned char *) 0xb0)#define TCCR2B (*(unsigned char *) 0xb1)#define TCNT2 (*(unsigned char *) 0xb2)#define OCR2A (*(unsigned char *) 0xb3)#define OCR2B (*(unsigned char *) 0xb4)#define ASSR (*(unsigned char *) 0xb6)#define TWBR (*(unsigned char *) 0xb8)#define TWSR (*(unsigned char *) 0xb9)#define TWAR (*(unsigned char *) 0xba)#define TWDR (*(unsigned char *) 0xbb)#define TWCR (*(unsigned char *) 0xbc)#define TWAMR (*(unsigned char *) 0xbd)#define UCSR0A (*(unsigned char *) 0xc0)#define UCSR0B (*(unsigned char *) 0xc1)#define UCSR0C (*(unsigned char *) 0xc2)#define UBRR0L (*(unsigned char *) 0xc4)#define UBRR0H (*(unsigned char *) 0xc5)#define UDR0 (*(unsigned char *) 0xc6)#define UCSR1A (*(unsigned char *) 0xc8)#define UCSR1B (*(unsigned char *) 0xc9)#define UCSR1C (*(unsigned char *) 0xca)#define UBRR1L (*(unsigned char *) 0xcc)#define UBRR1H (*(unsigned char *) 0xcd)#define UDR1 (*(unsigned char *) 0xce)#define UCSR2A (*(unsigned char *) 0xd0)#define UCSR2B (*(unsigned char *) 0xd1)#define UCSR2C (*(unsigned char *) 0xd2)#define UBRR2L (*(unsigned char *) 0xd4)#define UBRR2H (*(unsigned char *) 0xd5)#define UDR2 (*(unsigned char *) 0xd6)#define PINH (*(unsigned char *) 0x100)#define DDRH (*(unsigned char *) 0x101)#define PORTH (*(unsigned char *) 0x102)#define PINJ (*(unsigned char *) 0x103)#define DDRJ (*(unsigned char *) 0x104)#define PORTJ (*(unsigned char *) 0x105)#define PINK (*(unsigned char *) 0x106)#define DDRK (*(unsigned char *) 0x107)#define PORTK (*(unsigned char *) 0x108)#define PINL (*(unsigned char *) 0x109)#define DDRL (*(unsigned char *) 0x10a)#define PORTL (*(unsigned char *) 0x10b)#define TCCR5A (*(unsigned char *) 0x120)#define TCCR5B (*(unsigned char *) 0x121)#define TCCR5C (*(unsigned char *) 0x122)#define TCNT5L (*(unsigned char *) 0x124)#define TCNT5H (*(unsigned char *) 0x125)#define ICR5L (*(unsigned char *) 0x126)#define ICR5H (*(unsigned char *) 0x127)#define OCR5AL (*(unsigned char *) 0x128)#define OCR5AH (*(unsigned char *) 0x129)#define OCR5BL (*(unsigned char *) 0x12a)#define OCR5BH (*(unsigned char *) 0x12b)#define OCR5CL (*(unsigned char *) 0x12c)#define OCR5CH (*(unsigned char *) 0x12d)#define UCSR3A (*(unsigned char *) 0x130)#define UCSR3B (*(unsigned char *) 0x131)#define UCSR3C (*(unsigned char *) 0x132)#define UBRR3L (*(unsigned char *) 0x134)#define UBRR3H (*(unsigned char *) 0x135)#define UDR3 (*(unsigned char *) 0x136)// Interrupt vectors definitions#define INT0 2#define INT1 3#define INT2 4#define INT3 5#define INT4 6#define INT5 7#define INT6 8#define INT7 9#define PCINT0 10#define PCINT1 11#define PCINT2 12#define WDT 13#define TIM2_COMPA 14#define TIM2_COMPB 15#define TIM2_OVF 16#define TIM1_CAPT 17#define TIM1_COMPA 18#define TIM1_COMPB 19#define TIM1_COMPC 20#define TIM1_OVF 21#define TIM0_COMPA 22#define TIM0_COMPB 23#define TIM0_OVF 24#define SPI_STC 25#define USART0_RXC 26#define USART0_UDRE 27#define USART0_TXC 28#define ANA_COMP 29#define ADC_INT 30#define EE_RDY 31#define TIM3_CAPT 32#define TIM3_COMPA 33#define TIM3_COMPB 34#define TIM3_COMPC 35#define TIM3_OVF 36#define USART1_RXC 37#define USART1_UDRE 38#define USART1_TXC 39#define TWI 40#define SPM_READY 41#define TIM4_CAPT 42#define TIM4_COMPA 43#define TIM4_COMPB 44#define TIM4_COMPC 45#define TIM4_OVF 46#define TIM5_CAPT 47#define TIM5_COMPA 48#define TIM5_COMPB 49#define TIM5_COMPC 50#define TIM5_OVF 51#define USART2_RXC 52#define USART2_UDRE 53#define USART2_TXC 54#define USART3_RXC 55#define USART3_UDRE 56#define USART3_TXC 57#define USART_RXC USART0_RXC#define USART_DRE USART0_UDRE#define USART_TXC USART0_TXC// Needed by the power management functions (sleep.h)#define __SLEEP_SUPPORTED__#define __POWERDOWN_SUPPORTED__#define __POWERSAVE_SUPPORTED__#define __STANDBY_SUPPORTED__#define __EXTENDED_STANDBY_SUPPORTED__#asm #ifndef __SLEEP_DEFINED__ #define __SLEEP_DEFINED__ .EQU __se_bit=0x01 .EQU __sm_mask=0x0E .EQU __sm_powerdown=0x04 .EQU __sm_powersave=0x06 .EQU __sm_standby=0x0C .EQU __sm_ext_standby=0x0E .EQU __sm_adc_noise_red=0x02 .SET power_ctrl_reg=smcr #endif#endasm#endif
PORTL = (1 << 2); // PORTL.2 = 1
PORTL.2 = 1;
