Author Topic: Splitting Two Digit Number in AVRstudio  (Read 2880 times)
Offline airman00Topic starter
« on: September 05, 2009, 10:09:18 PM »
I read somewhere that AVRstudio rounds down numbers, so if I have 9.7, it will actually turn to 9. Is that correct?
Because I want to split a two digit number into two digits.
Is there a different method I can do?
Code:
int temp;
temp = Double Digits/10
temp*10 = First_digit
second_digit = Double_digits- first_digit
Example:
Double_digits = 15
15/10 = 1.5 , rounds down to 1 .
First digit = 1*10
Second_digit = 15 -10 = 5
    • RazorConcepts
Re: Splitting Two Digit Number in AVRstudio
« Reply #1 on: September 06, 2009, 12:41:26 AM »
Mod it, or %. Mod is basically what the remainder is.
17 % 10 = 7
9 % 2 = 1
Offline Pratheek
    • Probots
« Reply #2 on: September 06, 2009, 01:08:35 AM »
Like razor concepts said use mod operator.
Someting like this
int tmp = double_digits;
first_digit = tmp%10;
tmp /= 10;
second_digit = tmp;
« Reply #3 on: September 06, 2009, 08:28:00 AM »
Nope, its the compiler (in this case gcc) that does this. All programming languages to my knowledge do this for int types. :P
« Reply #4 on: September 06, 2009, 08:42:09 AM »
Thanks all!
This works:
   digit_1 = double_digits / 10;  // left most digit
   digit_2 = double_digits % 10;  // right most digit
