Author Topic: irrigation system using avr  (Read 2293 times)
Offline reem mohamedTopic starter
« on: September 07, 2009, 01:08:54 AM »
i want to make an irrigation system using avr (ATMega8535) the project is like that:
a canal has a water seneor to check the water level if it was low it stops the motor
then a stepper motor that helps in pumpin the water to the land
which by its turn has two sensors one to check when the land surface dries and open the motor and the other under the land and stops the motor when water reaches it..
their is a keypad & an LCD to put the passward which starts operating the motor
thx............
Re: irrigation system using avr
« Reply #1 on: September 07, 2009, 01:15:07 AM »
Good luck then.
Did you have a question to go with your project?
« Reply #2 on: September 07, 2009, 06:38:05 AM »
i think he/she wants advice on how to accomplish said project?
