Squirrels have fuzzy tails.
Many electrical outlets have fuses to protect from drawing too much. It really all depends on how your outlet is set up, I've seen many being able to handle 8 amps, and some even higher than that.
If you put many in parallel as Airman has suggested then I'm not sure what happens if they dont all give out an identical voltage. Will it be like causing a short circuit (ie bad)?
Reality check 2!That "few" servos aren't gonna eat 10A - make a serious calculation and you'll come to... much less.
There are three 1/4 scale servos, 2 standard sized but high torque servos (333 oz-in at 6V), 4 standard sized servos and about 4 mini servos. In my project so far. I'm also planning to integrate more for further articulation, so I'm looking for something to accomodate for this.
Counting all those servos and the possibility of adding future servos, 10 amps seems appropriate. If several or even all of the servos were stalling, which may be possible depending on the application, [...]
