Author Topic: Ground in DC power supply, what is it for?  (Read 4776 times)
Offline moodaengTopic starter
« on: September 12, 2009, 01:04:10 PM »
Hi Guys
            I am very new to electronics. I am wondering what is the Ground wire in DC power supply?
what is the different between this wire and V-   or V+ wires?  Why do we need them?
Offline Half Shell
Re: Ground in DC power supply, what is it for?
« Reply #1 on: September 12, 2009, 01:43:45 PM »
Edit: Apparently I was mistaken about something, please read further below.
« Last Edit: September 12, 2009, 09:28:05 PM by Half Shell »
« Reply #2 on: September 12, 2009, 01:48:46 PM »
so when I want to make 5 volt current from the machine
which channel should I plug black alligator into it? V- or Ground
When I plugged the wire into V-  / Ground the output is different.
is Ground channel equal to real earth ground?
« Reply #3 on: September 12, 2009, 02:16:18 PM »
Let's not get confused here...
Groun should be 0V (NOT -V), as 0V is the reference by which the amplitude of the positive or negative voltage is measured and ground should be neutral (again with respect to 0V => ground = 0V).
Some people might label ground as -V, but that's very wrong - please don't spread this wrong behaviour, standards shouldn't be "watered down".
On a battery (or cell) there is either 0V and +V, OR 0V and -V (this latter constellation is called positive ground).
