Author Topic: New to programming  (Read 2621 times)
Offline jessman275Topic starter
New to programming
« on: September 28, 2009, 06:56:07 PM »
So I purchased a Axon controller and started messing around with it. So far its works great.  I have looked around on the forums and have yet to find a topic about IR sensors and how they could control a motor or Solenoid. I have tried to program the controller by modifying some existing code and needless to say it didn't work.  I have purchased a IR sensors listed below
http://www.acroname.com/robotics/parts/R185-SINGLE-LINE-IR.html
I have used this type of sensor for data logging on cars before and had a great experience with it.
I would like to have the IR sensor pick up off a rotating object and activate a solenoid every time the white line comes around. I am very new to programming and have read many tutorials, but still haven't gotten the hang of it.
My Pseudo code looks like this
read IR sensor PORT,F1
if IR sensor detects line
   then activate relay on PORT E2 for 30ms
Can someone lead me in the right direction on how to solve this problem. If there is a tutorial out there that is similar to this that would help tremendously.
Jesse
Re: New to programming
« Reply #1 on: September 29, 2009, 09:20:16 AM »
Your pseudocode gets you 90% there.
becomes:
value=a2dConvert8bit(0);
read this:
http://www.societyofrobots.com/axon/axon_function_list.shtml#adc
if(value > 128)
read this:
http://www.societyofrobots.com/axon/axon_function_list.shtml#digital_output
you'll also need a MOSFET to drive your relay
you'll also need this to turn off the relay:
else
   PORT_OFF(PORTA,6);
so summing it up:
while(1)
if(value > 128)//depends on values you expect
    PORT_ON(PORTA,6);
else
    PORT_OFF(PORTA,6);
delay_ms(10);//prevent crazy fast oscillation
