Author Topic: snooper the robot  (Read 3059 times)
snooper the robot
« on: October 03, 2009, 04:49:02 PM »
here's my robot "Snooper". it uses 2 hacked micro servos for propulsion and runs off of an arduino. the power comes from 3 lithium ion batteries which i need to find a charger for. the camera is a cheep color camera from dx and the wireless transmitter is also from dx. i removed it's casing and hard soldered everything since the connections sucked. as you can see the arduino is just sitting on top for show right now and i'm working on a non permanent mount for it. the wireless has a range of at least 40 ft!
Next step: Give them vaginas
Offline Joker94
  • Helpful? 26
Re: snooper the robot
« Reply #1 on: October 03, 2009, 06:01:29 PM »
Nice job.
How heavy is it and do the servos have any trouble with the weight. As they are small. The reason i ask this is because i have 3 laying around but i have never used them for propultion before. And if you didn't have any trouble i might try them.
Again good job and nice bot ;D
« Reply #2 on: October 03, 2009, 06:12:00 PM »
Nice job.
thanks :D. the thing weighs less then a kg and the motors take the weight very well. they need allot of work for full rotation and there's no way arround using resistors unless you have an external pot since the pot is integral to the mechanics of it. you have to hack up the pot for full rotation as well which usually means massacring it but i havn't screwed one up yet. i'd say you could easily use them for the $50 robot for instance but i don't think i'd use one with anything that has a metal frame.
Offline Joker94
  • Helpful? 26
« Reply #3 on: October 03, 2009, 06:39:49 PM »
I was thinking along the lines of the $50 bot just for a platform to test my sensors and code so i don't have to keep getting out and starting up my ither robot. Which at the moment is not completed yet.
Thanks Blackbeard
« Reply #4 on: October 04, 2009, 01:03:15 PM »
hey anyone know any hexapod examples? i'm thinking of ditching the CD wheels and trying out legs. i've got 3 more of these servos (love them dx bulk rates :P) but only these 2 are full rotation now.
Offline Joker94
  • Helpful? 26
« Reply #5 on: October 09, 2009, 07:04:29 AM »
No sorry can not help there. i'll have a look when i get a chance.
I used to have one that i built from a kit but no longer have it. all i remember is there were two motors, one for each side of the robot.(i had this kit when i was about 10 so i don't remember a whole lot from it.
