Author Topic: servo question!  (Read 3909 times)
Offline AligatorTopic starter
servo question!
« on: October 07, 2009, 06:28:57 PM »
Hi
can i run my servos off my 5v regukator or do i need to supply it unregulated power.
Thanks in advance.
Offline madsci1016
  • Helpful? 43
    • Personal Website
Re: servo question!
« Reply #1 on: October 07, 2009, 06:37:22 PM »
You can, but watch how much current you try to pull through it. IF your regulator starts to heat up, it may need a heatsink or you are trying to use two many servos on one regulator.
 How many servos do you have?
Re: servo question!
« Reply #2 on: October 07, 2009, 06:57:15 PM »
well it is not a deatefinate answer as it is my own proto-dovelopment board so i guess it could be up to 5.is that to many.
i guess i may have to buy a 6v battery pack then, i guess i will get alot of use out of it so it is not as though it is a waste of money.
Offline galannthegreat
Re: servo question!
« Reply #3 on: October 07, 2009, 07:32:40 PM »
Powering servos from unregulated power is not a good thing because if you start to draw a lot of current through them, or when you have more of them, or you stall them, the current spike can affect your controller in a bad way. It's also good design to separate inductor type devices from other devices (just take the unregulated line and send it to the servo), just remember the common ground. :)
« Last Edit: October 07, 2009, 07:34:40 PM by galannthegreat »
Kurt
Re: servo question!
« Reply #4 on: October 08, 2009, 05:13:51 AM »
you mean regulated right?
Imo, dont use regulated power for servos, its just not worth it. The power wasted is huge and as galan said, it may cause power drops/spikes which may reset/fry your microcontroller. Rather just get another pack.
Offline kd5kfl
Re: servo question!
« Reply #5 on: October 08, 2009, 08:02:13 AM »
if you want regulated 5V, take it from your PC.
I have done this for years, never a problem. Running an OOPic and servos. puts some hash and trash on the 5 VDC, but it does not affect the computer.
Taking 5 VDC and 12 VDC from the disc drive power connectors
Re: servo question!
« Reply #6 on: October 08, 2009, 12:44:45 PM »
Whoops. Yes I meant regulated... Let's just say, it was a long day.
Kurt
Re: servo question!
« Reply #7 on: October 09, 2009, 01:56:35 AM »
You do realize that if you pull more than 500mA from a usb port it'll fry? Servos are not a good idea imo.
Re: servo question!
« Reply #8 on: October 09, 2009, 02:40:41 AM »
Trouble reaching the daily quota of posts?
No problem... Just don't read the posts you want to answer ;D
You are hereby declared the laughing stock for the next 16,2 minutes... Ha, that'll teach you (...or not - probably)
Offline madsci1016
  • Helpful? 43
    • Personal Website
Re: servo question!
« Reply #9 on: October 09, 2009, 06:11:11 AM »
He said to take it straight off the ATX power supply, which isn't a problem
Re: servo question!
« Reply #10 on: October 09, 2009, 06:41:41 AM »
Thanks for your replies.
Yes, good pick up.
I think i will go and buy a 6 v battery pack to power the servos.
Offline Joker94
  • Helpful? 26
Re: servo question!
« Reply #11 on: October 09, 2009, 06:42:59 AM »
I think that is the better option.
