Author Topic: delay_ms is stoping my program  (Read 3239 times)
Offline supernoobTopic starter
« on: October 15, 2009, 03:06:58 PM »
hello, I just got an Axon and am messing with it trying a few things being i dont have much programing experiance.
The problem is with the delay function during the button press. the sensor readings display fine in terminal untill i hit the button then the program seems to freeze. Why is this? even if i just set up a program to count and display the numbers in terminal it does the same thing unless i use a for loop instead of delay_ms(1000).
#include "SoR_Utils.h"
int main(void)
configure_ports();
uartInit(); // initialize the UART (serial port)
uartSetBaudRate(1, 115200); //set UARTD speed, for USB
//initialize analog to digital converter
a2dInit();
//configure ADC scaling
a2dSetPrescaler(ADC_PRESCALE_DIV32);
//configure ADC reference voltage
a2dSetReference(ADC_REFERENCE_AVCC);
rprintfInit(uart1SendByte);//USB
rprintf(" Hello, I'm working!");
LED_on();
while(1)
if(button_pressed())
servo(PORTC,0,700);// move the servo
delay_ms(20);
int se0;//variable to hold the data of the sensor
se0=a2dConvert8bit(0);//get the data and store it in se0
rprintf("%d\n",se0);//send the data to terminal
return 0;
//End main
Re: delay_ms is stoping my program
« Reply #1 on: October 15, 2009, 04:37:42 PM »
hmmm you are the second person to say this . . . I think a bug somehow creeped in the last code update . . .
For now just use delay_us() until I figure it out.
Sorry!
« Reply #2 on: October 15, 2009, 04:50:45 PM »
Cool thanx. delay_us works fine, so there must be a bug in delay_ms
« Last Edit: October 15, 2009, 06:16:25 PM by supernoob »
« Reply #3 on: October 19, 2009, 09:32:41 PM »
supernoob, you will be my test subject.
Download the attached timer640.c and replace it with the one you have.
Try it and let me know if delay_ms() works again.
ps - I didn't try it myself, I just stole some code from AVRlib, put it in, and it compiles fine.
« Reply #4 on: October 20, 2009, 02:40:58 PM »
It seems to be working fine now with that timer640 file. Guess there was a bug somewhere in the other?
Thankyou for the help.
« Reply #5 on: October 20, 2009, 02:48:30 PM »
Okie. Just report back here if any other timer problems pop up!
