Author Topic: need help from the older folks out there  (Read 2321 times)
« on: November 15, 2009, 03:20:07 PM »
so i've dug up my old function generator which i still have no idea how to use. when i say old i mean OLD as it's from the 1950s and uses vacuum tubes. the model is Ts-413C/U which from what i've read is a 1953-1954 US air force signal generator. it's in good condition and turns on well enough so i'd be willing to put it to work if i knew how to use it  i'm likely going to order a few tubes online for it in any case. so anyone know how to use it? here's a pic
[img=http://img4.imageshack.us/img4/3944/dscn7202s.th.jpg]
Next step: Give them vaginas
Re: need help from the older folks out there
« Reply #1 on: November 15, 2009, 04:55:11 PM »
Too bad the pic is so blurred, but are you sure it's a function generator?
It looks like a "measuring transmitter" (for lack of the correct English term) which is used to generate (whatever)HF+modulation for aligning receivers etc.
« Reply #2 on: November 15, 2009, 05:20:45 PM »
ok here's a better pic of one just like mine
http://photos.edebris.com/catalog/browse/4184/1/1/50/220271782d20010434252243f85be38d
it says it's a signal genorator but from what i can tell it's limited to 1vac
