Author Topic: Help on the $50 Robot circuit  (Read 2404 times)
Offline rollingrobotTopic starter
« on: November 22, 2009, 11:06:26 AM »
 My 5v regulator is going nuts with 9v battery plugged in and I think its because a bridge between GND and + via ceramic capacitor. My multimeter says there is 0 resistance between these two. I don't know what else to do. I tried resoldering and stuff. Maybe these two pics would help :x
Re: Help on the $50 Robot circuit
« Reply #1 on: November 22, 2009, 12:55:31 PM »
A little less solder would help - and more control with where it goes.
You probably created a solder bridge and judging from your photos, you really need to practise.
Desolder the entire circuit. Tin wire ends and pads. resolder with minimum amount of added solder.
« Reply #2 on: November 22, 2009, 02:33:09 PM »
Either the above or, trace around all the parts until you find where the bridge is... Otherwise soeren's option is all you have.
« Reply #3 on: November 22, 2009, 03:22:38 PM »
Isn't the 0.1uF capacitor the bridge? I just do not understand the purpose of the capacitor.
« Reply #4 on: November 22, 2009, 04:53:45 PM »
No, a capacitor should measure infinite ohms. It's purpose is to stabilize against noise transients.
Try reading through this Capacitor Tutorial
