Author Topic: AVR Frequency  (Read 2701 times)
Offline Joker94Topic starter
  • Helpful? 26
AVR Frequency
« on: November 27, 2009, 12:53:53 AM »
Hi
I have looked around but have found no conclusive answers.
My question is in "configuration Optioins"  what do i set the "frequency" as.
thanks Joker94
  • Helpful? 111
    • Webbot stuff
Re: AVR Frequency
« Reply #1 on: November 27, 2009, 12:57:25 AM »
For an ATMega8 (you dont say which AVR!)
The default frequency is 1000000 (!Mhz) unless you change the fuse bits to use 8000000 (8Mhz).
Of course if your board has an external clock then thats another story.
Sorry if I'm a bit vague - but so is your question!
  • Helpful? 26
Re: AVR Frequency
« Reply #2 on: November 27, 2009, 01:11:20 AM »
extremley sorry i thought of all of those things but forget to add them when writing the question.
It is pretty much the $50 robot board. So Atmega 8.
Hope that helps
thanks again
Offline devlaam
Re: AVR Frequency
« Reply #3 on: November 27, 2009, 03:33:57 AM »
As the atmega8 does not have a hardware prescaler i really think you have to fuse it to 8MHz if you want to use that frequency.
At the same time, you can enter that value at the configuration options.  Otherwise, if you have the default, you set it to 1MHz
Ruud.
