Author Topic: sharp ir 90° rotation  (Read 2325 times)
Offline manutTopic starter
« on: December 19, 2009, 03:11:11 PM »
hi everybody,
  I proudly  ;) finished the sharp ir 50$ robot, it works well, it follows me  :)  ..but the servo (that can rotate 180°) just scans 90°, is it  normal? .., I heard to talk about 2 sharp ir for one robot, is it the way to make it scan 180°? does it mean that if I want a robot able to scan all around it, I should install 4 sharp ir to achieve it?
thanx
manu
Offline z.s.tar.gz
  • Linux Guru
Re: sharp ir 90° rotation
« Reply #1 on: December 19, 2009, 03:24:21 PM »
It should be able to scan 180°, as  only thing keeping it from doing so is the code. I would say that isn't 'normal'.
Also, there are several reasons that two IR's would be used, but to get 180° isn't one of them.
On another note, 3 sensors would be needed to get a full 360°, as two servos will have a 'blind spot' between them.
« Last Edit: December 19, 2009, 03:26:08 PM by z.s.tar.gz »
« Reply #2 on: December 19, 2009, 05:42:57 PM »
okay, thank you for explanations.. I think I'm going to ask for this in the programmation part of the forum..
