Author Topic: how this robot work ?  (Read 2358 times)
Offline mcmanTopic starter
« on: December 20, 2009, 03:35:35 AM »
What is the name of this spherical robot that done in CMU
This robot can move and have only one point that touch the ground and use gyroscope sensors
Re: how this robot work ?
« Reply #1 on: December 20, 2009, 03:53:31 AM »
That is the ballbot.
The robot has gyro's, as you said. It takes readings from the gyro's and determines the angle of the robot.
If it is not straight up it will try to adjust this by moving.
It moves by having two rollers roll against the big ball, one for x and one for y.
http://www.msl.ri.cmu.edu/projects/ballbot/
I am pretty sure there is more info elsewhere. Ill see if i can track it down.
