Buy an Axon, Axon II, or Axon Mote and build a great robot, while helping to support SoR.
IntroductionRoMeo is an All-in-One microcontroller especially designed for robotics application. Benefit from Arduino open source platform, it is supported by thousands of open source codes, and can be easily expanded with most Arduino Shields. The integrated 2 way DC motor driver and wireless socket gives a much easier way to start your robotic project. The most important about this board is that it is Arduino compatible which means you can use Romeo as a standard Arduino Nano board.SpecificationAtmega 32814 Channels Digital I/O6 PWM Channels (Pin11,Pin10,Pin9,Pin6,Pin5,Pin3)8 Channels 10-bit Analog I/O USB interfaceAuto sensing/switching power inputICSP header for direct program downloadSerial Interface TTL LevelSupport AREFSupport Male and Female Pin HeaderIntegrated sockets for APC220 RF Module and DF-Bluetooth ModuleFive I2C Interface Pin SetsTwo way Motor Drive with 2A maximum current 7 key inputsDC Supply:USB Powered or External 7V~12V DCDC Output:5V /3.3V DC and External Power OutputDimension:90x80mm
