Squirrels have fuzzy tails.
I haven't been able to find what the Axon uart is using, so I stick with N81 for the comm settings.
Is there any conceivable way to test the uart1 port from the mcu?At this point I have no way of knowing if it is working correctly.How can I guarantee that it is working?
What mac setup are you using and what OS are you using. 10.4.11 is what i use and it is non compatiable with most the serial to usb devices due to a bug in the OS. to my knowledge anything over that or under it should work though... Truckstop
Quote from: emoseman on August 13, 2009, 10:33:22 PMIs there any conceivable way to test the uart1 port from the mcu?At this point I have no way of knowing if it is working correctly.How can I guarantee that it is working?You can easily test it on any windows machine.Also, just in case, verify that your fuses still look like this:http://www.societyofrobots.com/axon/axon_FAQ.shtml#fusesSorry, but I don't know enough about macs to help much more . . .
