Author Topic: Can anyone suggest an off the shelf kit?  (Read 3189 times)
Offline mawgTopic starter
« on: September 08, 2009, 09:11:00 PM »
hi, I wonder if anyone can help suggest an off the shelf kit.
What I am really doing id demonstrating remote control over satellite, but it might make it easier for potential clients to grasp if they can see a simple demo.
I need a robot of some sort which I can control from a PC (preferably with an attached cable, although I suppose IR communication would be acceptable).
Beyond that the PC needs to be able to order the robot do something - anything at all: move, pick something up, it doesn't really matter)
Additionally, the robot needs to report something to the user: again, it can be anything at all, maybe even a simple light sensor, or that it hit a wall.
For reason that I won't go into, a small robotic arm, capable of lifting, moving and dropping a small wooden block would be ideal, with some form of sensor giving any kind of feedback (need not be related to the arm, could just be a light sensor attached to it).
Can anyone suggest something cheap & cheerful that fulfils those requirements? (I don't have much budget)
Thanks in advance for any help which you can give me.
Offline billhowl
  • Helpful? 32
Re: Can anyone suggest an off the shelf kit?
« Reply #1 on: September 09, 2009, 05:37:31 AM »
Try this The Experimental Robot Platform by SoR-Admin using Bluetooth communication
http://www.societyofrobots.com/robot_ERP.shtml
Offline Half Shell
« Reply #2 on: September 09, 2009, 08:40:59 AM »
Knowing your budget, instead of just thinking of it as "small", will greatly help steer our advice.
« Reply #3 on: September 09, 2009, 09:34:56 AM »
I'm not aware of any kit that does all that you listed. It'd require quite a bit of modding.
The kits that are close to what you want will be a minimum of $500, and more likely $1k after modding it.
« Reply #4 on: September 09, 2009, 08:54:45 PM »
Quote from: Half Shell link=topic=9040.msg70394#msg70394 date=1252507259
[/quote
A good point. Basically, my budget is "as cheap as possible" so long as it can 1) be controlled from a PC and 2) can report some sort of feedback to the PC. I don't really have to be an arm, for instance.
It seems that lego midstorms give quite a bang for the (three hundred) bucks. Does it have a rival?
Thanks for the reply.
« Reply #5 on: September 09, 2009, 08:57:48 PM »
Wow, that does look impressive. It is beginning to look like a choice between that, which ought to cost less but require more time, and midstorms.
Thanks for the information.
Offline Joker94
  • Helpful? 26
« Reply #6 on: September 09, 2009, 09:06:00 PM »
just remember there is an entire forum here to help you out :D
