Author Topic: robot arm chassis  (Read 5103 times)
Offline icoms8Topic starter
robot arm chassis
« on: October 12, 2009, 09:02:14 PM »
What would be the best material to use on a robot arm? I'm using 4-5 hs-311 and 1-2 are on the gripper and 1 is the bottom that moves the whole arm if i have to change the bottom servo so it can move more i can but what kind should i get? The arm wont lift much mabye a few grams.
Offline galannthegreat
Re: robot arm chassis
« Reply #1 on: October 13, 2009, 12:23:52 AM »
If you're going to use it for very light things Sintra (expanded PVC) would work great. It is very easy to work with, and at 6mm thick it has some decent strength too.
http://www.solarbotics.com/products/sin6mm/
Just a suggestion of a personal preference of mine. :)
Kurt
Offline dellagd
    • Exodus Rocketry
« Reply #2 on: October 13, 2009, 05:15:58 AM »
I've attempted a robot arm, and bear in mind, theres gonna be a lot of leverage on thoese small servos.
If I helped, +1 helpful pls
I Won!
3rd place! I'm taking $100
« Reply #3 on: October 13, 2009, 06:03:09 PM »
That made no sense to me?
Are you sure the 311's can take all that load? 2+ servos+the materials+the load?
Offline dellagd
    • Exodus Rocketry
« Reply #4 on: October 13, 2009, 06:16:04 PM »
look at this
I Won!
« Reply #5 on: October 13, 2009, 06:37:10 PM »
Yeah, i get that... but leverage doesnt seem like the right word? thats what confused me...
if you want to try and explain it to me, do it over pm's, we dont want to flood this topic :)
« Reply #6 on: October 14, 2009, 08:37:00 PM »
The strongest and lightest! :P
(you need to choose the one best for your application - if we don't know any details, we can't help!)
read this:
http://www.societyofrobots.com/mechanics_statics.shtml
http://www.societyofrobots.com/robot_faq.shtml#robot_arm
look at this
dellagd, I think you meant 'torque', not force :P
Offline dellagd
    • Exodus Rocketry
« Reply #7 on: October 15, 2009, 05:06:59 AM »
(facepalm) yes!
I Won!
« Reply #8 on: October 15, 2009, 05:32:48 AM »
So does the leverage thing still go? And isn't torque a measurement of force?
« Last Edit: October 15, 2009, 05:35:54 AM by SmAsH »
« Reply #9 on: October 15, 2009, 08:04:10 AM »
Torque is moment of a force, it's a measure of a force related to an axis (in this case the main output gear is the axis). While leverage is the action of a lever, or the mechanical advantage of a lever.
Kurt
