Author Topic: HELP!!!!!!!!!!  (Read 2984 times)
Offline noahTopic starter
HELP!!!!!!!!!!
« on: January 20, 2009, 08:06:36 PM »
Help! I am a beginner. I have next to nothing when it comes to hands-on sexperience with robotics, ( only theory ) and I have like,three weeks to build a robot for a Science Olympiad competition size,power limited please, if you are reading this HELP ME! please recommend part suppliers,materials,and I really need full directions on how to build a robotic arm. The limitations are: battery cannot exceed 9.6Vs,enter robot must fit inside 30centimeters square, (1 foot) nothing complex, please something RC and please explain the wiring that connects the servos to the battery,remote receiver,so forth.Diagrams would be help full,As I said I only have three weeks(@#$$%) so please respond via this site or my gmail ( [email protected]) ANYTHING would be helpful thanks,
        Noah
« Last Edit: January 20, 2009, 08:30:52 PM by noah »
Offline cooldog
Re: HELP!!!!!!!!!!
« Reply #1 on: January 20, 2009, 09:17:16 PM »
okay for starters when u post a topic pls put a more descriptive title.
http://www.societyofrobots.com/robotforum/index.php?topic=602.0
http://www.societyofrobots.com/robotforum/index.php?topic=1480.0
so to get this staight u need a rc arm that will fit in a 1ftX1ft box (pls put more description on what it is suppost to do)
how many joints do you need
http://www.societyofrobots.com/robot_arm_calculator.shtml
this will tell you what motors to use.
first search the forum
http://www.societyofrobots.com/robotforum/index.php?action=search2
or google
this is a robot arm that Admin made.
http://www.societyofrobots.com/robot_arm_card_dealer.shtml
Admins robot arm tutorial
http://www.societyofrobots.com/robot_arm_tutorial.shtml
Materials
http://www.societyofrobots.com/robot_parts_list.shtml
we can NOT build the robot for u
a rc robot is really simple you will need a hobby rc controller check
http://www.ebay.com/
or
http://www.societyofrobots.com/robot_parts_list_RC.shtml
they are a simple plug and play device the servos just plug staight into the reciver and they will work without programming
[youtube]GfJMeH9asec[/youtube]
your power limitations should not be a problem or your size requierments
-admin
favorite web sites
http://www.instructables.com/
Offline Spoil9
Re: HELP!!!!!!!!!!
« Reply #2 on: January 20, 2009, 09:24:16 PM »
For the robot arm I would check out lynxmotion.com They have a nice kit but it may be a bit out of your price range.
Otherwise servocity.com and sparkfun electronics and Trossen Robotics are all great sites. And thats only four off the top of my head.
For the 9.6v battery, any 9.6v RC car battery would work great. Visit a local hobby shop for those, and if there is no limit get the ones with the highest mAh for the longest run time.
For all my RC stuff I would either visit a local hobby shop or towerhobbies.com They usually have cheap radios that can be used and sometimes have deals where you buy a radio and get the receiver and servos for free.
For the wiring, it all depends on what you get and what you want to add later on but if you know the theory of electronics then this should not be an issue for you as most of it is plug and play anyways.
If you only got 3 weeks, then you better get cracking and divide up your time between researching parts, ordering parts, prototyping, building, and lastly testing. Sounds like you only got about 3 days to do each step, and that's assuming parts arrive in order and on time.
Good luck and if you have more specific questions, feel free to ask.
- Will
Knowledge is Power. Power Corrupts. Study Hard. Be Evil.
Re: HELP!!!!!!!!!!
« Reply #3 on: January 20, 2009, 09:50:44 PM »
1 of u guys asked for more description:robot has 2 move AA,AAA batteries and golf balls,lego blocks and coins into a score area measuring 4 feet by 4 feet divided into 4 score areas. the objects listed vary in points depending on which score area it is deposited. thank you all for your input!
        Noah
« Last Edit: January 21, 2009, 10:07:19 AM by noah »
Re: HELP!!!!!!!!!!
« Reply #4 on: January 20, 2009, 10:51:43 PM »
    • RazorConcepts
Re: HELP!!!!!!!!!!
« Reply #5 on: January 21, 2009, 11:10:20 AM »
That model is a vintage one, I would go for something more modern. Look for the futaba 6 channel series.
Offline Spoil9
Re: HELP!!!!!!!!!!
« Reply #6 on: January 21, 2009, 07:28:32 PM »
And although they are cheaper, stay away from AM radios as I am told they get a lot of interference from outside sources so you may be telling your robot to move forward, but because of interference it moves semi-circle.
