Steps to Brazing
Step 1 - Clean Your Parts
Capillary action will work properly only when the surfaces of the metals are clean. If they are "contaminated"
- coated with oil, grease, rust, scale or just plain dirt - those contaminants have to be removed.
If you do not remove these contaminants, they will form a barrier between the base metal surfaces and the brazing materials.
An oily base metal, for example, will repel the flux, leaving bare spots that oxidize under heat and result in voids.
Oil and grease will carbonize when heated, forming a film over which the filler metal will not flow.
And brazing filler metal won't bond to a rusty surface. Cleaning the metal parts is seldom a complicated job,
but it has to be done in the right sequence. Oil and grease should be removed first, because an acid pickle
solution aimed to remove rust and scale won't work on a greasy surface.
(If you try to remove rust or scale by abrasive cleaning, before getting rid of the oil, you'll wind up scrubbing the oil,
as well as fine abrasive powder, more deeply into the surface.)
Start by getting rid of oil and grease. In most cases you can do it very easily either by dipping the parts into
a suitable degreasing solvent, by vapor degreasing, or by alkaline or aqueous cleaning. Dishwashing detergent should work.
If the metal surfaces are coated with oxide or scale, you can remove those contaminants chemically or mechanically.
For chemical removal, use an acid pickle treatment, making sure that the chemicals are compatible with the base metals being cleaned,
and that no acid traces remain in crevices or blind holes. Mechanical removal calls for abrasive cleaning.
Particularly in repair brazing, where parts may be very dirty or heavily rusted, you can speed the cleaning process
by using emery cloth, grinding wheel, or file or grit blast, followed by a rinsing operation.
Once the parts are thoroughly clean, it's a good idea to flux and braze as soon as possible.
That way, there's the least chance for recontamination of surfaces by dust or body oils deposited through handling.
Step 2 - Brazing Location Setup
The location and setup for brazing is important. Brazing outside in bright sunlight is bad, in that you will not
be able to see your flame. Brazing inside is bad in that you need poisonous fume ventilation. I personally use
a fume hood, but a shaded well ventilated area should suffice.
Next you need to secure the parts you wish to braze. What you use to mount your parts should have
low heat conductivity (resists getting hot, like ceramic, concrete, steel, etc). When mounting your parts, try to leave
a small gap between the two parts that will be brazed. For capillary action to be effective,
joint clearances of 0.002 to 0.006 inch (50 to 150 um) are recommended.
Step 3 - Flux Your Parts
Flux is a chemical compound applied to the joint surfaces before brazing.
Heating a metal surface accelerates the formation of oxides, the result of chemical combination between the hot metal
and oxygen in the air. Oxides will inhibit the brazing filler metal from bonding to your part surfaces.
A coating of flux on the joint area, however, will shield the surfaces from the air, preventing oxide formation.
Flux will also dissolve and absorb any oxides that form during heating or that were not completely removed in the cleaning process.
Choose the flux formulated for the specific metals, temperatures, and conditions of your brazing application.
Cover any surfaces that will be brazed completely and thoroughly right before brazing.
Think of the flux as a sort of blotter. It absorbs oxides like a sponge absorbs water. An insufficient amount of
flux will quickly become saturated and lose its effectiveness. A flux that absorbs less oxides not only insures a better joint
than a totally saturated flux, but it is a lot easier to wash off after the brazed joint is completed. Flux can also act
as a temperature indicator, minimizing the chance of overheating the parts. For example, some types of flux become completely
clear and active at brazing temperature - telling you that the base metal is just about hot enough to melt the brazing filler metal.
Also, you may want to add some flux to the end of the filler metal rod to improve the flow.
Step 4 - Brazing
The actual brazing step is probably the easiest and quickest of the steps. If you are a novice, dont worry it is really
easy, almost self-explanatory. Simply heat the joint between
the two metals that you wish to join until just before they start to glow red (or until the flux becomes clear).
Both metals in the assembly should be heated as uniformly as possible so they reach brazing temperature at the same time.
Then touch the filler rod to the joint, and just let it melt right into the joint by itself.
Molten brazing filler metal tends to flow toward areas of higher temperature. Remember, the filler will spread
itself through capillary action.
This is an example of proper brazing technique:
Step 5: Cleaning the Brazed Joint
After you've brazed the assembly, you must clean it. Cleaning is usually a two-step operation.
- First - removal of the flux residues
- hot water bath
- then a hot hydrochloric acid bath
- Second - pickling to remove any oxide scale formed during the brazing process
Flux removal is a simple, but essential operation.
Flux residues are chemically corrosive and, if not removed, could weaken certain joints. Since most brazing fluxes are water soluble,
the easiest way to remove flux is to quench the assembly in hot water (120F/50C or hotter).
Your best bet is to immerse them while they're still hot, just making sure that the filler metal has solidified completely before quenching.
The glass-like flux residues will usually crack and flake off. If they're a little stubborn,
brush them lightly with a wire brush while the assembly is still in the hot water. Using live steam will work too.
The only time you run into trouble removing flux is when you haven't used enough of it to begin with, or you've overheated the parts during the brazing process.
Then the flux becomes totally saturated with oxides, usually turning green or black. In this case, the flux has to be removed by a mild acid solution.
A 25% hydrochloric acid bath (commonly found in some toilet bowl cleaners and etching compounds), heated to 140- 160F/60-70C, will usually dissolve the most
stubborn flux residues. Simply agitate the brazed assembly in this solution for 30 seconds to 2 minutes. No need to brush.
A word of caution: acid solutions are potent. So when quenching hot brazed assemblies in an acid bath, be sure to wear a face shield and gloves.
After you've gotten rid of the flux, use a pickling solution (such as Sparex precious metal cleaner) to remove any oxides that remain
on areas that were unprotected by flux during the brazing process. The best pickle to use is generally the one recommended by
the manufacturer of the brazing materials you're using. In the few instances where you need an ultra-clean finish, you can
get it by polishing the assembly with a fine emery cloth.
Safety in Brazing
In brazing, there is always the possibility of dangerous fumes and gases rising from base
metal coatings, ink, and cadmium-bearing filler metals, and from fluorides in fluxes. The
following well-tested precautions should be followed to guard against any hazard from these fumes.
Ventilate confined areas. Use ventilating fans and exhaust/fume hoods to carry all fumes
and gases away from work, and air supplied respirators as required. I personally just use a fume hood,
but doing the work outside will be fine too. Just don't do it on a bright sunny day as you wont
be able to see the flame from your butane torch.
Clean base metals thoroughly. A surface contaminant of unknown composition on base metals may add to
fume hazard and may cause a too rapid breakdown of flux, leading to over heating.
Heat the base metals broadly and uniformly. Intense localized heating uses up flux, increasing the danger of fuming.
Use sufficient flux. Flux protects base metals and filler metal during heating cycle.
Full flux coverage reduces fuming. Read the warning labels on the flux container.
Know your base metals. A cadmium coating on a base metal will volatilize and produce toxic fumes during heating.
Zinc coatings (galvanized) will also fume when heated. It is recommended to remove these coatings before parts are heated for brazing.
Be especially careful not to overheat the assembly when using filler metals that contain cadmium. Read
all warning labels on the brazing rod packaging.
Wear safety goggles and rubber gloves when using the pickling solutions. Read warning labels.
Dispose of all chemicals properly - don't just pour it down the drain!
More Information
I want to recommend this brazing tutorial.
My tutorial just skims over the need to know basics, but this tutorial goes into serious detail if you are interested in perfecting
your brazing skills.
