Capacity Selection
Force overload is the primary reason for transducer failure,
although the process of selecting the right force capacity
looks easy and straight forward. There are several terms you must understand
to properly select for load capacity:
The measuring range is the range of values of mass for which the result of
measurement is not affected by outer limit error.
The safe load/torque limit is the maximum load/torque that can be applied without
producing a permanent shift in the performance characteristics beyond specified.
The safe side load is the maximum load that can act 90 degrees to the axis along which
the transducer is designed to be loaded at without producing a permanent shift in the
performance beyond specified.
A force transducer will perform within specifications until the safe
load/torque limit or safe side load limit is passed. Beyond this
point, even for a very short period of time, the transducer
will be permanently damaged.
Capacity Selection, Derating
Unfortunately you cannot just rate your transducer by
static forces alone.
There are many additional issues you must be concerned about:
- Shock loading (sudden short term forces)
- Dynamic influences (momentum)
- Off centre distribution of force
- The possibility of an overload weight/torque
- Strain Gauge Fatigue (constant use and wear)
- Cable Entry Fatigue (the output wire bending a lot)
If there is a possibility that any of these may occur, you must then derate
your force sensor (use a higher capacity). For example, if you
expect a high fatigue rate, you should multiply your required capacity
by two. Make sure you understand what you are measuring so that you do not
waste money on a soon-to-be-broken force transducer. Over time, you may want to
recalibrate your sensor occasionally in case of long term fatigue damage.
Damage
Because force transducers are expensive, preventing them from being
damaged should be a high priority. There are many ways to damage
a transducer. Shock, overloading, lightning strikes or heavy surges in
current, chemical or moisture ingress, mishandling
(dropping, pulling on cable, etc.),
vibration, seismic events, or internal component
malfunctioning to name a few.
If your sensor becomes damaged, don't just re-calibrate it.
Mechanical failure may have catastrophic effects and you
will no longer have a reliable sensor.
Lightning
"Investigations indicate that a lightning strike within a
900ft radius of the geometrical centre of the site will
definitely have a detrimental effect on the weighbridge."
In most cases, the actual damage is a direct result of
a potential difference (1000+ volts) between the sensor circuit and sensor housing.
If lighting strikes commonly happen near your area,
make all grounds on your circuit common so the voltage floats together -
and use surge protectors! And of course, no electric welding should be
done near your sensor (hey, it has happened).
Moisture
Obviously, water and electronics do not mix. Force transducers
are always sealed to keep out the elements, however moisture/condensation
damage occurs from a slow seeping over a long period of time.
The damage can be multiplied when acids or alkalines are present.
The most likely entry area for moisture is at the cable entry point,
so it is important to keep this area protected more than any other.
Manufactures employ many techniques to seal it off, but there are additional
techniques you the user can also employ. Know that often temperature changes
can cause a pumping action to
occur, pushing moisture down the inside of the
cable. Entry also can be via a leaking junction box or through
a damaged part of the cable. This can take some time to reach
critical areas, but once there it will become sealed in place and
do critical damage.
Corrosion
The effects of corrosion on your force transducer will be the result
of both the manufacturing quality and the environment in which the sensor is used.
Make sure you understand how likely your choice in transducer
is likely to corrode over time. Consider the metal type of the outer
casing, the surface finish, the weld areas, thickness/quality of moisture seals,
and cable material (PVC, PUR, or teflon).
Also understand the environment - salt water, for
example, has different corrosion effects depending on the local
circumstances. Stainless steel in stagnant salt water is subject
to crevice corrosion (a regular wash down is necessary to
avoid degradation).
Don't assume stainless steel means "no corrosion, no problem and no maintenance".
In certain applications, painted or plated load cells may offer better long-term
protection.
An alternative is wrap-around protective covers. These can
provide good environmental protection, but can be self destructive
if corrosive material is trapped inside the cover.
Sealing compounds and rubbers used on some transducers can deteriorate
when exposed to chemicals or direct sunlight. Because
they embrittle rubber, chlorine-based compounds are a particular problem.
Always make sure you keep your sensor maintained and clean to avoid corrosion.
Installation
There are several considerations that are often forgotten during the mounting
of force transducers. For example, it is a common misconception
that a force transducer can be considered as a solid piece of metal on which
other parts can be mounted. The performance of
a force transducer depends primarily on its ability to deflect repeatably
under conditions when load/torque is applied or removed. Make sure
all supports are designed to avoid lateral forces, bending moments,
torsion moments, off center loading, and vibration.
These effects not only compromise the performance of
your force transducer, but they can also lead to permanent damage. Also,
consider self aligning mounts.
The S-Beam Load Cell Changes Shape Under Load
Force Transducer Cables
Special attention should be paid in preventing the transducer
cable from being damaged during and after installation. Never
carry transducers at their cables and provide dripping loops to
prevent water from running directly into the cable entry.
Don't forget to provide adequate protection for the
cable, near the sensor if possible.
Load cells are always produced with a four- or six-wire cable. A
four-wire cable is calibrated and temperature
compensated with a certain length of cable. The
performance of the load cell, in terms of temperature
stability, will be compromised if the cable is cut; never cut
a four-wire load cell cable! 6 wire cables can be cut, but all
wires must be cut evenly to avoid any differences.
Extras
What I have talked about is actually a very watered down tutorial for
force transducers. If you would like to learn more, read the
advanced load cell tutorial.
I didn't write it, so good luck!
You may also be interested in the data logging
tutorial so that you can log your force/torque sensor data effectively.
