Planetary Gears (~80% efficiency)
Planetary gears have the highest commercially available gear ratios you would ever want to put
on a robot. But since they are somewhat complicated, you would never need to build one, just use it.
The datasheet should tell you the gearing ratio - I just wanted you to know if you need a really
really high gearing ratio for a robot, planetary gears are the way to go. Even better, some planetary
gears offer multiple gearing ratio's that are user configurable!
More Information
If you wish for an even more in-depth tutorial about gear selection, you can find it in this
advanced gear selection tutorial.
I didn't write it, but it's easy to follow and understand. Where can you buy gears? Check my
robot parts list and the ad window at the top right of this page
for links.
