Search and Index Search Here
    ROBOT SPEED CALCULATOR
    this calculator written by forum user nottoooily
    Use this calculator if you already know the robots' physical and motor specs to calculate the speed of your robot.
    note: If you do not know which motor to use, the Robot Motor Factor Calculator determines the required motor, given your required robot specs.
    Desired Robot Inputs:
    These are the specs of your robot, defining the properties and a candidate motor.
    Mass
    Rolling Resistance
    Incline Angle degrees
    Wheel Diameter
    # of Powered Wheels wheels
    Motor's No-Load Speed
    Motor's Stall Torque
    Minimum Required
    Performance Results:
    This is the calculated output results.
    Hill Climbing
    Top Speed
    Time to Reach 50% of Top Speed s
    Time to Reach 90% of Top Speed s
    At Top Speed the motors spin at of their no-load speed.
    On Flat Terrain
    Top Speed
